I need some input as to the sound deadening properties of the commonly available cork roadbed when placed on 3/8" plywood. Is it enough or would is a layer of foam under the cork the best way to go? Thanks!
Well, I don’t use foam for a layout base, but was surprised to read that it’s not all that good for suppressing sound. Cork isn’t bad, but ballasting will negate some of its sound-deadening properties.
I have noticed that layouts on Homasote are fairly quiet, whether or not there’s cork atop it.
A plywood tabletop can really amplify sound, especially of it’s not well-supported. My layout’s upper level is on a well-supported base, with ballasted cork under most of the track, and I’m not really bothered by the sound. However, my layout is DC-powered, so there are no sound effects to be drowned out by ambient layout noise.
My experience with cork, foam, and now Homasote, is that once the ballast is glued down most of the sound dampening qualities are gone.
With track loosely fastened, cork seems to be the best, but Ballast needs to glued down.
-Kevin
I agree with Kevin’s observation. When things are fastened together, sound absorption disappears.
Its the vibration created by the moving trains that gets amplified throughout the structure is what causes the noise. Generally, the denser and heavier the benchwork, the less the trains will cause it to vibrate.
If you ran trains on benchwork made of concrete, you’d probably not hear any noise transmission.
Multiple layers of different substances tend to vibrate at different frequencies, so they may cancel each other out. If you’re really concerned about absolute quiet, probably make a sandwich of various materials and fasten them together with caulk to change the frequency. But that’s a lot of work for probably marginal gain.
My layout is HO and I have cork on top of ½” plywood as well as on ¼” OSB for my elevated runs. I use Elmer’s white glue diluted 8:1 to anchor my ballast and the wheel sound through the roadbed is very minimal.
I don’t ballast the track (coded 100) in my hidden areas, only my viewable track is ballasted (code 83).
When I have a train running on my hidden track under my mountains I can’t hear them running. If I had multiple trains running it could prove hazardous without my signal system. I have a hidden siding where I park a full train and I had to put in optical detection front and rear so I could park them.
Mel
My Model Railroad
After standing in a corner for two-three days feeling a little ashamed. I can tell you this.
I gave too much time up worrying about the same thing you’re worrying about.
Don’t worry about sound and clickety clack. That is what a train going down the tracks is supposed to sound like. Just ask Johnny Cash, He put it in his music.
Don’t get me wrong. Take your time with it, don’t be in a hurry. Just lay your tracks to the best of your ability and that will be fine… cork is good and the sound of your trains going down the track is good no matter how loud it is, even better!
Trains are big machines and make a lot of noise!
TF
I heard the sound of a train coming from a room away and the clickety clack from one of our forums members basement in Wisconsin a few weeks ago.
I liked it!
I must hear different things. My last layoout was foam, with cork roadbed. The part I got ballasted was in no way louder than the part that was unballasted. In fact it was probably quieter.
The roadbed and the track were fastened with caulk, not nails or a hard drying glue. The ballast was glued - we have hard water here so I just dilute the glue with 70% alcohol. What I’ve found is that when this sets up, the PVA (Elmer’s white glue) remains a bit rubbery, compared to full strength white glue. Perhaps that’s the difference.
I did a little test but I don;t have a sound meter, in which I tried cork and homasote roadbed on 3/4" plywood, though withoout fastening anything down. Didn;t seem to be a huge difference between the two, but what really was silent was putting homasote roadbed over cork on the plywood. But to do that would require buying rolls of cork and cutting my own wide enough to then support the homasote roadbed on top of it. None of the options produced onbjectionable noise, so I doubt I will use 2 layers of roadbed.
it depends on what you’re trying to achieve … trains normally aren’t quiet , lol
I have been playing with trains, better then 15 years. On plywood and foam, with and without roadbed. I sill do not hear this godawfull.overbaring,can’t standable noise, every ones crying about.
If a toy train running is so unbareable, how do you even dare to walk outside? go to work or have the TV on ?
[Y][Y][Y][Y][Y] Well said and what else can we start to worry about here? [:(][(-D]
TF
In my observation, much of the “noise” from rolling stock is related more to the construction of said rolling stock rather than the trackwork.
This came to my attention recently after finishing up a few HO Life-Like Proto 2000 Mather box car kits. Usually I use the Kadee wheelsets but in this case I used the (old stock) Life-Like, plated, rib-backed wheels. Once I set them on the rails I noticed a much louder sound coming off the moving cars.
I have scores of old Proto 2000 cars on the layout. I never really observed this before so there might be something different with the plating on these wheels. All three of the kits I finished exhibit the same, noticably louder wheel noise.
Same thing with brass cars. They are a natural sounding board for the vibrations inherent in the rolling wheels. I’ve begun placing cubes of lightweight, soft foam inside cars when it can be concealed and that helps reduce extraneous noise considerably.
I’m with others here, though. I rather enjoy the sound of my trains running and that includes the rail/wheel sounds.
Regards, Ed
Thanks for the replies, everyone! My layout is a 2’ 4" x 7’ shelf and, although my switching operations will all be at low speed, I’m just concerned about a drumming sound from an idling loco and short runs. The plywood top is screwed down well onto the frame and to a support in the center. I think that I’ll be okay with this sized layout using cork roadbed on the plywood. Maybe I can run a test with some straight cork roadbed pads and a length of flex track just in case. I just don’t want to get everything down only to hear aggravating noise, that’s all.
Slow switching speeds should be fine. I run at about 20 to 25 scale mph, so the drumming can hit my ear at times.
At switching speeds, modern well built models with can motors and metal wheels will probably sound more like ball bearings rolling on glass more than anything.
As others have noted, in my experience, taking an extra sound deadening step didn’t seem to make a difference in road noise.
On my previous layout, the norm was cork roadbed on 1/2" ply with caulk, track layed with caulk, and ballast glued down with matte medium (more flexible than white glue). As an experiment, I tried adding an additional layer of cork (1/8" thick) with caulk on the subroadbed. The added cork was wide enough so that the ballast didn’t contact the subroadbed.
I couldn’t detect any difference sound-wise.
Jim
If you want to quit down the sound, you need to will in the sounding board we make with the way we build our railroads. We are basically building drums so any sound mitigation must be made under the railroad. It is surprising how just a skirt in front can cut down the sound alot.
P2K wheels seem louder than others. All oof my rolling stock has P2K wheels, unless the original came with metal wheels/ The loudest sound, on my hoome layout or at the club, is a SSSSSSSSSS sound of the wheels rolling on the rails. I used P2K wheels because prior to Walthers buying LL, they were insanely inexpensive, at least from Modeltrainstuff. I think around $3.99 a pack at the time, each pack is good foor 3 cars. At the club, we have a connection that can get the boxes of 100 Intermountain wheelsets for what works out to be a quite similar price, so most of the club rolling stock and other members have Intermountain wheels - when one of those trains rolls past, it doesn;t have the SSSSSSSSS sound mine do.
Surface, structure, ballast - seem to have rather minimal effect, unless you are trying something really exotic.
ANd adding additional layers of the same thing will have almost no effect - the sound is attentuated most when it passes from a material of one density to one of another. 3 layers of different materials will be better than 2 layers of one plus a second material (ie, homsasote, cork, plywood vs 2 layers of cork on plywood). Carried to an extreme, say 5 layers of varying materials, you probably could make an almost 100% silent roadbed, but is it worth it? Coonsider how loud it is sitting in yoour car at a grade crossing, let alone standing trackside watching the train come through.
Ironically, back in the 1950s when plastic (often nylon) wheels and trucks were a new product, they were praised for being so much quieter than metal, which of course they are. The irony is that these days “first thing you do, replace plastic wheels with metal” is standard advice which I myself follow, usually. True, back in the 1950s more modelers used wood roadbed such as TruScale, which perhaps made the noise problem worse. Locomotives tended to be noisier then as well.
Maybe the main thing that can be said for cork roadbed (and of Atlas’s brief 1960s experiment with rubber roadbed) is that at least is doesn’t make the matter of sound and noise worse.
Different forms of benchwork seem to transmit or create/amplify noise differently, and some benchwork actually simulates a drum or stringed instrument in construction. I suspect it could be possible to introduce trimmed rubber sheeting as a sort of gasket between various wood joints in our benchwork to minimize noise, acting rather like a “mute” does on a violin or cello: it reduces the transmission of vibrations into the box-like body of the instrument. And vibration is what makes noise.
But you’d have to think about doing that very early in the process.
Dave Nelson
I used Midwest Products cork roadbed. I noticed that when I used the “cookie-cutter” method for subroadbed, as opposed to using a flat sheet of plywood, it cut down on noise. Ballasting track directly attached to foam increased the noise.
Two comments I have on this are, it is the metal wheels that produce most of the noise as I discovered when I stuck track right to cement board.
Two, the biggest determining factor on layout noise is what’s on the floor under the layout. You will notice a huge change if you move your layout on to a carpeted surface from a cement or ceramic tile type surface. If noise is a concern make like a recording studio where they have partitions with heavy carpet underlay stuck to them, just do the same but on the horizontal.
A few more thoughts:
I never really understood the push to replace plastic wheels with metal wheels, both by modelers at home and by the producers. Plastic wheels aren’t bright and shiny, and truck/wheelsets like Athearn BB, which were abundant and cheap, are just as free rolling as just about anything.
My new layout, I will have the multiple layer of different materials in mind. Track will be caulked to Homasote Homabed, which will be caulked to ceiling tiles, laid loosely on 1/2 inch plywood shelf benchwork and held firm by a surrounding boarder of 1x2s and the backdrop. There will be minimal under trackage scenery but where there will be, some creative stacking of the tiles will have to be designed. That doesn’t seem like a whole lot of extra work to me.
