The projections that Cushing, OK is going to not have enough room to store crude, may create an interesting situation.
The idea is to store oil in railcars, like say plastic pellets get stored around Houston. Already oil traders are using old supertanker and oil barges to store unsold oil.
My thought is, I think there is a supply of DOT 111 Tank Cars still out there that could be used to store oil, not move the oil just store it. With the changes in rules the DOT 111 cars became obsolete.
I suspect that storing loaded cars would generate pushback from the local community, unless they’re in the middle of nowhere. And there is security to consider…
The great joy of this is that you COULD still move the cars around with the oil loaded – just as a special move, and not very fast, in a fully-buffered unit train. (You could arrange to remove and re-use the buffer cars with a little care; keep them with whatever you use for power).
Probably lots. As I recall, scrap was in the toilet, really costing more to clean and cut up than the product would be worth, before the current shutdown effects. More and more sellers would come out of the woodwork as you started to show the ability to pay something more than their holders think they’re worth. But the asked price would probably start going up once they understand what you’re doing. Perhaps the better question is how you lock in storage space on all sorts of sidings, yard tracks, unused secondary mains and the like – miles and miles and miles of parked tanks (see item 3) and then how you keep goobers away from vandalism or theft. Hard to watch all those cars all the time.
I suspect the somewhat extended answer to this depends, to start with, if the oil has been properly ‘degassed’ to get the low-boiling fractions out of it. The ‘danger’ then becomes that any safety-valve releases vent hydrocarbons in
This would involve more work, but you could buy some land in, say, the Mojave desert away from everything, build heavy duty fixed stands to connect with the truck bolsters, and then remove the cars from their trucks and place them on the stands. That way you could put them closely in rows and pipe them together for a quick tank farm.
Of course, you lose the benefits of mobility, but if they’re not legal for oil service anyway, then it’s an easier way to fit a lot of them into a space where they won’t attract a lot of negative attention.
While the tank cars are on the railroad, they are under FRA regulations. If you remove the wheels and set the cars on blocks, they are now subject to various state oil and gas regulatory control (which might involve envoronmental containment and monitoring) and local fire marshall inspections. Old barges/tankers used for storage would need to meet Coast Guard regulations.
No, and to be blunt it is a stupid question. If you gave it a little thought and used the computer you askerd it on, you would know that. A “supertanker” carries 2,000,000 barrels of oil. That will fill 2790 tank cars. They will need over 21 miles of track. That should tell you NO in very loud terms. We haven’t gone into the cost of unloading, loading, switching, and moving them to this 21 miles of track that is not available. All this for a product that has a negative value. While it is on the ship at $.15 /bbl/day you can redirect it anywhere you might find a buyer. Why spend 10 times that to put it in a container that you can not ship it in? And if you could it would be limited to the North American rail system.
For oil pumped in the heartland such as from the Bakken or Uinta Basins that aren’t connected to the pipeline system, and with storage capacity full, it probably won’t get hauled to tidewater to be pumped in to a tanker. That is not to mention if there are tankers even available as other counties are also filling tankers as fast as they get them to port. The glut of oil is enormous as economies across the world grind down to depression levels.
If you’re going to store cars, there’s usually a charge, by the car, by the day. Odds are the cars would get stored on otherwise unused shortline rails. I’m sure if they’re loaded, they’ll charge a premium price.
Two dollars a day per car adds up pretty quick - and that’s the going rate for empty cars…
With the amount of tank cars needed to fill up a tanker or barge,you might be hard-pressed to find the number of cars needed. It may come as a surprise to some, but a lot of the DOT111A cars are being–and have been–rebuilt with insulation, thicker head shields, etc., to make them usable for crude transport.
Just read an article in the 04/24/20 on line edition of the Wall Street Journal about the oil glut and storage issues related to it. Most of the oil is being stored in tank farms and on tankers. But, right in the middle of the article is a picture of rows and rows of tank cars in a Russian rail yard full of stored crude oil. So, is it going to solve the problem? No. Might there be some trainloads of stored crude out there in places besides Russia? Quite possibly.
It is my understanding that the oil glut has reduced its value to zero. So you either have to pay to store it or pay to dispose of it. Meanwhile this economic oil war is destroying our oil industry which cannot compete with free oil. So when this finally stablilizes we will again be at the mercy of foreign oil sources.
It’s much more complicated than that; the most ‘significant’ part is that much of the effect of the continued low demand is on the workers in the oil-supply industry … or on the exploration and new-development industries, or on those with higher prices of production (where the profit from oil goes to zero or negative)
So we can proceed directly to your second point – which I think is valid as stated, so no further need for posters to dispute ‘the price of oil’ question – and ask what will be done to preserve jobs, knowledge, etc. for domestic firms and individuals concerned in the ‘oil industry’. I’d be particularly interested in seeing what people actually involved with it, like Midland Mike, have to say, particularly including what strategies should be used either in ‘stimulus’ or in developing approaches to economic recovery.
That is easily possible, but the profit needs to be high enough to cover the cost of storing the oil, the rental of equipment, handing and transportation to put the oil into storage and then taking it back out of storage, and the cost of insurance and security.
