Coupling N scale Gunderson MAXI I Double Stacks
I am having a terrible time trying to couple the N scale Gunderson MAXI I articulated stack cars. It appears the articulation joints must be in a certain order as there is a notch in the middle of the top of one side but not the other. I have the cars aligned in the correct A-E order and have all but one spot left to couple, but it simply will not go. I have seen a YouTube video showing how it should be done, but this simply does not work at this one spot. It also mentions a 3-2-1-2-3 order on the box, but I don’t know what this means.
WBLOCK,
It would help a lot,if you would mention,who made them,Walthers,Athearn,Atlas,A-Line,they have all made them and they do not all work the same way…
Cheers,
Frank
WBLOCK,
It would help a lot,if you would mention,who made them,Walthers,Athearn,Atlas,A-Line,they have all made them and they do not all work the same way…Gunderson Maxi I is the prototype Manufacturer…
Cheers,
Frank
Kato makes them and here’s a video from Mike Fifer who contributes here http://www.youtube.com/watch?v=632K7Gm4BI
Gary,
Thanks, for saying who made them and the video,I watched the first 8 seconds of it,and the phrase that stuck out was,read the directions on the bottom of the box…
I’m in HO only,but was just curious as to the OPs questions…
Cheers,
Frank
hahaha, wait we have to read the box? [:$] I didn’t know.
