CP Rail no. 1907 pictures
Hi,
I´m searching for pictures of CP Rail F9b no.1907. Can anyone help me?
Christian from Germany!
Image result for F9B 1907
Rapido
CP 1907.
Note horn upper left near end for hostling.
http://www.mountainrailway.com/Roster%20Archive/CP%201900A/CP%201907.htm
Thank You.
Thanks, and can you say me how you call the think on the top and middle of the roof?
Christian(Huetherchristian@aol.com)
I believe you refer to the "Winterization Hatch, the large box?
It was designed to pre-warm the intake air in colder climates. The C-P ones seem taller than many I’m used to seeing in other North America railroads.
https://www.shapeways.com/product/FYGB3E8WH/cpr-f-unit-winter-hatch
More mention of them here:
https://rapidotrains.com/ho-gmd-f7b-f9b
Regards, Ed
No,I m mean the high part in the middle of the roof. That part the other F9b not have.
Christian!
If you mean the funnel (cone) looking thing I believe it is part of the engine cooling water fill/vent. That seems to be a modification (experiment?) that only the C-P did on certain locomotives and not others.
Some C-P GMD F9Bs had fuel tank vents piped to the roof, too. Maybe that is what you see?
Just my guess as to what you might be asking about.
Thank You, Ed
