First post on this forum. I need to know which size crossings I should use for #4 Atlas Custom Line turnouts and what would the track spacing look like?
I am planning an extension to my current shelf layout and any info would be appreciated.
The Atlas 25° crossing will work with Atlas #4 turnouts to make a double crossover. I do not know the track spacing.
I used a 19° crossing to make my #6 double crossover. I had to do some serious cutting on the turnouts and the crossover to end up with 2” center to center double track mainline. The standard spacing for manufactured double crossovers is 2”. I started out using a code 83 Shinohara Double Crossover and it wouldn’t pass my Rivarossi Articulateds with non RP25 wheel flanges. None of the commercially made code 83 turnouts would pass the large flange wheels without a problem so I made my own using Atlas turnouts and crossover.
One of the important features of the Atlas Custom Line track system is that the turnouts make crossovers (single crossovers) @ 2" track centers with no spacer track and no modifications.
The 19 degree and 25 degree crossing will make double crossovers with wider track centers, but again with no spacer tracks.
Years (decades) ago Atlas published a book of track plans which also explained all their track geometry.
They’ve republsihed some of the plan books with different names, but the one I have that has several pages in the back showing all sorts of track arrangements possible with the Custom Line components is “Custom Line Layouts for HO Scale Railroads”. Might get lucky and find a library with a copy, or else find a copy at a train show.
As Randy mentions, any Atlas track planning book I have ever seen, has a section ln the back with all sorts of combinations. They have several options so that you can have a variety of track spacings between parallel tracks and the needed crossings and length of spacers to give you the desired spacing. A lot of handy ideas in one place.
