I don’t see how having a longer minimum radius is a benefit, unless you’re working with very restricted room.
I didn’t have a track plan when my just barely-started benchwork was relegated to a much smaller (and oddly-shaped) room.
I decided that I needed a couple of parameters within which to work, and those turned out to be maximum radius possible wherever curves were necessary (and with 10 corners in the room, there were lots of curves), and non-confining aisle-space.
I didn’t do any calculations for easements, so simply let the Atlas flex track “relax” itself at the point where I thought that the actual curve should end.
While the minimum radius turned out to be 30" (on all three legs of a wye, and again, I think, although it may be 32", on a double track section around one of the outside corners of the room.
Everywhere else it’s 34" or greater, up to 48’ in a couple of areas (used simply because there happened to be enough room at that location -ya gotta have some places for nothin’ but track and scenery).
All of the curves have easements, and most have superelevation, with vertical easements in and out of all superelevation, including that on S-bends.
Of course, in-truth there was more room for most of those curves, but I didn’t want to sacrifice scenic areas on the limited area which was used for the actual layout - wide curves look great, but even not-so-wide ones look pretty darn good when located in an interesting setting, the latter being of more interest to me.
Oh, and as far as aisle space is concerned, I achieved my goals pretty-well throughout the layout room, with one exception. It’s fortunate that I’m a lone operator, but even th
