There is really no rule for easements, less is more than none. More is better than less.
More or less[swg] It depends on what kind of room you have.
It may be debatable, but on an extremely slight curve, I don’t personally believe you need them. An extremely slight curve is an easement on its own. There are those that will disagree with that. They are not wrong. More is always better than less and less is always better than none.
Tighter curves, you definitely want them. Unfortunately sometimes on a tighter curve you don’t have room for them. That’s why one ends up with a tighter curve in the first place. But then again, this is where careful layout planning is really important. It can prevent a situation such as this before it happens and it’s too late to go back to the drawing board[;)]
You can make a conceptual drawing, certainly, but I found it so much easier to use John Armstrong’s yardstick method for easements-- what you want is a smooth, gradual, spiraling transition from straight (tangent) into the body of the curve, so fix around 6" at one end of the yardstick in place where the track is still straight, then gently bend it at the other end until it matches the curve radius you’re after.
Hope this helps.
I have a hunch that if you had a properly eased tight curve (say 18" in HO), more rolling stock would accept that than a non-eased slightly less tight curve (say 22"). I’ve never put that to the test, though.
Thinking of this a bit more complicatedly for a moment: negotiating a curve at a given ‘track speed’ involves a constant angular acceleration (as in orbital mechanics). What you’re doing with the transition spiral is smoothly accelerating laterally from zero (at the end of the ‘tangent’) to full (through the apex) at a tolerable rate. (This is the same sort of thing you do when driving your car, turning the wheel at a constant rate until reaching the apex of a turn and then unwinding at constant rate until going straight…)
MR published a ‘spiral’ template that did this well for typical model radii. This could be simply copied from the magazine and cut from plastic or even card stock for the gauge.
The alternative is to use a drafting French curve to get a smooth transition – starting of course further into the ‘straight’ tangents on either end of the curve – and use the result as a centerline. You could also set off about half model track gauge and make an inside-rail template if you like that method better.
Pay very careful attention as you bend the rail, whether in Flextrack or handlaid, not to kink it. It is very wise not to have rail joints, soldered or not, in the area being spiraled unless you have the tools and experience to bend rail accurately net of springback to precise shape.
Incidentally both in real life and in modeling there is a comparable transition curve for vertical accommodation, both in raising an outside rail for superelevation and as part of compensated grades. This is generally easier to implement (with careful roadbed design and track securement) than lateral spiral, but I think it is just as essential to smooth running.
You will find “Easy Easements for Model Train Track” at this MR site under How To / Track Planning & Operation. Apparently edited in 2017, as I used a prior version dated 2010. It is easy if using flextrack. It does not have to be a precise formula, just directionally better than a sudden change from constant curve to tangent. The track looks more realistic and the train running through an easement looks more realistic as well.
Easements are highly over rated, depending on the trackplan. They look much nicer but function wize do little unless you have a large engine. I boils down to what are you running.
I imagine they are easy once done a time or two- actually what I was stumbling on was the length and amount of offset, but Paul’s link cleared that up. My last layout wasn’t planned for them even though a few appeared just with the nature of my laying track freeform without a plan, just an idea in my head. As for what I will be running- I have limited myself to nothing over 40’ rolling stock and late steam/ early diesel (F units, gp7, rs1’s, etc). However I do have a few older brass loco’s, mostly mike’s, that I wish to run as well. Kev
Brass steam locomotives can be a challenge on any radius under 32", depending upon the actual model in question. I had a 1968 Balboa SP MK-5 2-8-2 recently that really did not like anything under Kato 28.75" radius track. I had a W&R/Samhongsa (1999) 2-8-2 that was designed for 24" to 26" radius, depending upon individual installation of cab curtains. Other W&R/Samhongsa 2-8-2’s are designed for 28" and 30" operation, depending upon the model and detailing. They come with an instruction sheet.
Any brass engine with a 4-wheel (two axles) lead truck or trailing truck can be a problem, as the truck may hit the cylinder block on some radii or else piping details under the cab. You may find that you need to replace the springs with tighter springs to keep lead and trailing trucks from derailing on “tight” radius such as 24".
The old PFM brass model catalogs clearly state the design radius for most of those models, BUT that assumes you have virtually perfect trackwork and NO vertical kinks, as brass engines do not like vertical kinks at a track joint. Also, replacement of factory original brass brakeshoes with plastic can enable the model to negotiate tighter radii, as in some cases it is the brakeshoes that short as the radius is decreased below 30" radius. I just sold some brass steamers because they could not handle portions of my layout that are 26.375" Kato radius, and I can’t rebuild them, so I’m very familiar with the limitations of brass models.
If using sectional track, Armstrong did recommend using one section of a larger radius at each end of a curve to provide the easement effect rather then trying to curve by eye or other methods.
Also, it should be noted for those using Kato Unitrack that they now actually have superelevation transition track and fully superelevated curved track available for purchase, and I did just use it to relay part of my mainline to
I’ll have moved again by th end of next month, so I get a chance to start over and do things better, even though it will be less space. I remember being a kid with my 1st layout and trying to get that athearn dd-40 around those 18" curves… (anyone else been there- done that?). The first thing I’ll be doing is laying out some test curves to see what I’ll have to have just for the brass, and even though I’d love to have a GN R-2, 40" curves in a 10 x 10 room… I’m hoping to get away with 28" radius with easements, but we’ll see… Kev
Years ago I made my own templates using the spiral easement formula. I find the templates make laying out the easements very easy to do.
The October 1969 Model Railroader has several easement templates that can be used.
But I also find that setting up a temporary oval with sectional track (no easements) seems to work just fine if the curves are appropriate for the equipment.
Appearance is the operative word here. Easements do improve appearance and something else that really can improve appearance and remove some of the toy like look of a MRR is to change the radius as you go through the curve. Too many track plans just look stamped out. As an example, if you start with a 32" curve opening it up to a 40" as you go through the curve, it is very appealing to the eye.
Offset in HO scale is 1/8". I didn’t bother measuring length on my last layout. I stopped spiking a foot and a half or so back and just bent the track into the curve. The easement shaped itself naturally. Also, if your offset is more than 1/8 inch that’s okay. I eyeballed everything after the first one or two.
Really, I cannot overstate how simple it is to make easements.
I like the idea and the appearance of easements, especially since I have a twice-around folded loop with a central operating ‘pit’ and enjoy photography. Rather than do the math and draw the centerline, I just let the flex track make it’s own approximation of a spiral curve. It does a passable job. Also, I don’t have problems with kinks in the middle of curves if I have to have a joint there. I stagger the sliding rail and use half-joiners (cut with a jeweler’s saw that I solder. This allows me to leave more ties in place with those important little spikehead details that help to generate a smooth curve, kink-free.
This is a photo of tracks in my helix, last layout. This joint had to be good and reliable as it was all inside a large ‘mountain’. I hadn’t cleaned the area after soldering and filing, so it’s untidy. You can make out the half joiner leaving enough room to obviate having to remove any of the ties. A fair bit more ‘bother’, but it made superb curves.
That’s awesome selector. I never thought of half joiners and that you stagger your joints is a great idea. And I see you kill two birds with one stone with your feeder wires there as well[Y] You must have some kind of trick to do both at one time without the feeders wanting to come loose during the soldering process?
Now that I think about it a bit more, I’m pretty sure it’s actually a 1/3 joiner, at least in that photo. A half joiner would still be too large to fit between two tie spikehead sets, especially since they move somewhat closer on a curve…as designed.
The feeder was added later, and just happens to be co-located with that particular joiner. Don’t recall why I chose that spot…
Now that I know the idea works … a simple way to do this is to use two types of solder with different melting points: hard-solder the track joint, and then use additional solder and appropriate flux to add the feeder. Would be a cinch with a temperature-controlled iron.
