http://cs.trains.com/mrr/m/mrr-layouts/2288297.aspx
Is or has anyone ever done this before? Its a cheap HO scale Life-Like GP38-2. I’ve shaved off the plastic moldings of the marker lights from the short hood, cut off the side window dividers and I sprayed it with a light coat of white primer so i can see all the details in the body. ( its actually a Santa-Fe warbonnet, fictionally numbered 3500.) I also shaved off the upside down headlight hoods to give it a clean look, And I replaced the old style couplers with some Life-Like knuckle couplers I had lying around. Next I,m going to remove the white primer, cause i came out crappy (any suggestions on how i should?) and sand all the rough surfaces smooth, then I’ll hit it with a light coat of grey primer. Please let me know what else you think I should do to it to make it more realistic, what road I should make it and if you’ve done anything like it yourself.
Thank you.
