Firstly, thanks you guys for all of you advice and help so far, it is moving my first track layout right along.
I need to know now…What is the best tool to use or the best way to cut a piece of flex track.
My second question is about layout terrain. I am trying to go from a lush green grass to a more “stubbled, spotty” look. Any suggestion of where I can look to get some tips and guidance to achieve this terrain look.
Like JaBaer I’ve used a Dremel cutoff blade for years, being carful it leaves the best cut finish on the rail ends. About 20 or so years ago I bought a Xuron track cutting tool and it also leaves a clean cut but to be perfect a small metal file is needed to clean up the rail ends.
About two years ago I bought a Harbor Freight Xuron look-a-like cutter and it does very well, it’s a bit shorter tool than the Xuron and can get into slightly tighter places.
Check out YouTube for “How To” videos for tips on scenery, using “Model Railroad Scenery” in the search bar. There are “How To” videos on YouTube for all Model Railroad ventures.
If you are doing it on the cheap, use Xuron rail nippers, and don’t use them for anything else as harder metals can damage them.
I’ve found that cutting rail with Xuron, they still need to be filed bcause the Xuron does not cut it perfectly square - it is left with a bit of a point. So you will need the Xuron plus a file.
For a long time, I have used a Dremel with cut off discs rather than the Xuron I have - I only use the Xuron to cut a large piece of flex down to a shorter piece and then use the Dremel to trim the rail to the exact length I need to fit it in place.
I’ve found the thin cut off discs break very easily so I used the thicker ones mostly anymore. Another thing to be aware of when you are cutting rail, it can get quite hot from the friction and ties can melt. The precision of a Demel over the Xuron makes it worth cutting that way for me, so I have found ways to mitigate heat issues.
You can pull the sliding rail out if it is Atlas flex, to give it some distance from the ties. You can also use a heat sink to pull heat off if the rail is fixed. I have set of old Radio Shack heat sinks I use for soldering and cutting rail, just clip on and go to work. Easy. Alligator clips work if you can’t find the standard heat sink.
I find cutting rail with a Dremel is much preferable to the Xuron despite the precautions needed because of the precision and results I get. I can cut rail very precisely to the exact length I need with the Demel. This is especially important when fitting a section of track into a space between track that is already laid. I wouldn’t be able to get it cut to the exact length with a Xuron.
LION use Dremel Tool. LION mostly cuts track in situ. That is on the layout rather than on the bench. Because of shape of tool, and big furry paw of LION, cut is never vertical, but at an angle. No problem is this worry not about it at all.
LION never own Xuron tool. Ho is it at cutting track in place on the layout. Say you want a gap, or you want to install a switch, or replace a lenght that is not good.
LION solder all rail joints of him. Need to take out a switch or other peice of track, cut the joiner with the Motor Tool, then use solder iron to remove the remains of the joiner. Slip new joiners all the way on the replacement rail, drop it in place, and then move the joiners into place. Job done. If not can do, just solder a bar to the outside of the rail, instant joiner.
Buy the Xuron tool!!! Be aware only one side will be flush and the othher pointed. Much more persise than a Dremel unless you have a lot of practice with the Dremel and even then, you can’t get a 90 degree cut if track is in place with a Dremel but you can with a Xuron. Most tools, you don’t need the brand name for even pro jobs if you know what you are doing (was in the trades for years) but the Xuron is one of the few exceptions, own two!
I start out with the Fine Turf, then add Coarse Turf, then Bushes and Clump Foliage. A little experimentation will give you the desired look and texture.
When cutting flex track that has not yet been installed I use a Dremel tool with a reinforced cutting wheel – the “standard” thin discs just shatter too readily. I hold the track near the edge of a table so that I can make a clean 90 degree angle cut.
I might add that I use the MLR solder tool that holds track in place and in gauge while soldering to hold the track near the cut. This gives you something to hold on to that won’t get red hot and also seems to minimize the risk of the track going out of gauge due to slightly softened ties.
When cutting track already laid I sometimes use the Dremel (and the largest cutting disc I can find) but I do not like the angle that is usually created so use either a saw (Atlas makes a perfectly servicable one; there is also Zona) or a Xuron cutter. I always file the end to make it neat and make sure to file the base as well just to make sure there is no bump for the rail joiner.
When when sawing I like to use a MLR solder tool just to make sure the rail is not being pulled away from the plastic nubs.
Xuron tool when cutting free ends for a custom set, but use a cut-off wheel when trimming or gapping rails already set in place.
Reasoning: Xuron is quick, no cords, no rotating disk to accidentally snag or cut items nearby…fingers, tree armatures or branches, ties, grit or ballast grains…etc. Additionally, all cut rail ends should be dressed, if briefly, to ensure smooth running of the tiny scale wheels over them. The top bearing surface of the rail head should have a slight bevel/champher, and so should the inside flange face of the same rail head. It is hard to do this for a gap left by a cut-off disk, but a needle file dragged along the gap will do a bit of what I show in the diagramme below:
I saw this being done at a model railroad show demonstration a number of years ago. Few swipes with a file and done. Quite quick and easy. No goggles needed.
Yep, because Xuron doesn’t cut the rail square on both sides, it is beveled so you do need to file it - which is fine. Rail is soft so it doesn’t take long to file it flush and even. But even after using the Xuron, I still prefer my Dremel (or choose your brand) with the thicker cut off wheel. That my personal preference after laying quite a bit of track, I always go back to it.
With my Dremel, if I were to cut rail in-place, the cut would be at an angle because I can’t get the Dremel parallel with the rail - impossible unless I had a flexy shaft, which I don’t. So I always lift the rail and cut it so I can make the cut at a 90 degree angle and the drop it down in place.
I fixed that problem with the right angle attachment. I also use the fiberglass reinforced cut-off wheels which are a larger diameter and make it easier to get a perpendicular cut.
I always size check, mark and cut flex track before I anchor it to the roadbed, so I seldom have to cut in place. For ‘midair’ cutting, my weapon of choice is a modified pair of diagonal cutting pliers (outer surface filed flat) purchased at Ronstedt’s in Tucson long before Xuron tools became available. Like the Xuron tool, it leaves one side flat and the other mangled. Flattening the other cut end requires sacrificing about 1/8 inch of rail, which ends up as a nickel-silver nugget.
Dressing the rail end as Crandell illustrated is absolutely essential to derailment-free operation unless you can align rail ends with the accuracy of a Swiss watchmaker. That’s ALL rail ends, even the point heels and closure rails of turnouts…
Chuck (Modeling Central Japan in September, 1964 - with trackwork as bulletproof as I can make it)
I also use an Xuron track cutting tool to cut track that has not been installed. Generally no goggles are needed, but if cutting very close to the end of the rail (say within 1/4"), goggles should be worn because the small piece of rail may go flying.
Still reccommend safety glasses, even with Xuron rail nippers.
For electrical gap on already installed rail though, Dremmel with the reinforced cutoff disk. Along with safety glasses, and long sleeves… A face shield, if available, would not hurt either…
