Started up my 2-10-2 yesterday after a bit, and found I somehow have the settings so that the sound cuts out when the headlight is turned off.
Yet the setting for mute is still normal F8 and works…but I have no sound unless the headlight is on.
Can’t see in the JMRI panels where I have a setting wrong. The Function controls looked to be checked correctly and normal. I think they are all on the default settings.
I wonder what I have done. I suppose I could reset everything.
However, after resetting the mute off and on again and writing the changes a couple of times to the decoder the problem seems solved. Now works properly.
I guess it was a minor imperfection that righted itself.
