Hello All,
Many model locomotives run at unrealistically high speeds at “full throttle” and don’t respond well at factory-set lower-speed steps.
The majority of my motive fleet has Digitrax decoders; both sound and non-sound.
In the literature provided with Digitrax decoders, there is a chart labeled; “Speed Tables-How the Loco Responds to the Throttle.”
It lists the “Loco Type”; Switcher, Road Switcher, and Mainline Loco, with suggested CV values for V Start (CV02), V Mid (CV06) and V Max (CV05) for how each one responds to the throttle steps be it 14, 28 or 126 (128).
According to Digittax, adjusting these three (3) CVs changes the throttle response in the following manner:
- “Switcher- -Concentrated low speed. Limited top speed.”
- “Road Switcher- -Prototypical top speed w/evenly distributed curve from 0 to top speed.”
- “Mainline Loco- -Quick increase to cursing speed then levels of to prototypical top speed.”
When setting up locomotives, other than speed-matching MU’ed locomotives, do you adjust the speed(s) depending on locomotive type?
If you do adjust the speed(s) do you use CV 02, 06, and 05?
Do you use the speed table function; JMRI or another CV programmer?
Or, do you just limit the top speed manually with your throttle no matter the speed steps; 14, 28, or 126 (128) and top speed of the loco?
Some decoders support a “Switching” mode, enabled by a function command.
Does anyone use this function?
Thank you in advance for your thoughtful and respectful responses.
