RT&S reports Dallas Dart light rail temps are reaching 150 F. Report says CAT is sagging as well. Brings up question constant tension CAT? If constant tension was it so hot that the weights hit the ground or some stop on poles? It may be a repeat of the problems Portland, Oregon had with their light rail when it got so hot last year.
I know nothing about the Dallas light rail operation.
Just speculating from afar, I suspect the highway grade crossing as well as whatever signal system they are running is keeping the segments of welded rail short enough that all the insulated joints that are requried for both crossing protection and signal system effectively prevent their welded rail generating sun kinks as the insulated joint give the rail a place to move when hot. On the Class 1 carriers the segments of welded rail can approach three miles in length before coming upon a set of insulated joints.
Back in the days of jointed rail, having the rail run because of heat extremes was virtually unheard of. There were rail joints every 39 feet and those joints could easily attenuate heat expansion of small fractions of a inch per rail length. I have a MofW Rail Expansion Chart - a 1000 foot segment of rail is expected to expand 3 1/8 inches for a 40 degree increase in temperature. 5280 feet to the mile, three miles to a signal block - 15840 fee - equals 49.5 inches of expansion - over 4 feet - 4 feet of ENERGY that the entirety of the track structure is attempting to hold in place. It only takes the slightest of failure to any one element of the track structure and you have a sun kink.
Most current insulated joints are epoxy glued and tightly bolted and have NO movement of the rails unlike the older fiber non-glued insulated joints of old. The glued joints are prefabricated and welded (thermite) into the long rails and can not relieve the stress.
The new insulated joints, when installed, have no movement. After enduring multiple heat/freeze/thaw cycles by they hundreds and thousands they do develop movement.
