DC turnout-controlled signals
Hi all,
I’m planning to run a DC layout and will have manually-thrown, electrified-frog turnouts. I’m thinking about setting up a signal system where the turnout is thrown by hand and the polarity of the frog determines the aspect of the signal. This is easy enough to do with simple reversible red/green LEDs, but I also want to be able to change aspects based on direction, which seems to complicate things…
I have an Arduino that might be good for sending commands to different signals, turning them red, green, yellow or lunar based first on direction from the DC powerpack and then second on input coming from the frogs. But I can’t figure out a good way to wire the frogs to the Arduino, since their polarity will keep changing. Do I need something like a pair of opposite-faced diodes in parallel to divert different polarities to input/ground? Has anybody used Arduino to control their signals?
Thanks,
P
I havn’t used or worked with the Arduino system, but isn’t it a programable computer chip? If so, why can’t you set up the frog polarity as an input to the chip that will sense the positive or negative voltage? (If input pin 1 is positive, do this, if not, do that.)
It is a programmable chip, but the current going in and out of it is DC. The issue is that the digital pins can be programmed either as sink (other end is +) or source (other end is -), but not both at the same time AFAIK. Reverse current in the wrong place could fry the chip. I figured that a diode could be hooked up to prevent one polarity from reaching the pins, and another diode in parallel could direct that flow to ground-- thus the pin would read either voltage or nothing and use that difference to set the signal aspect. If there’s a way to take the +12v/-12v range from the frog and change it to +5v/0v, that would work too.
P
Edit: I remembered soon after hitting ‘Submit’ that sourcing/sinking only applies when the pins are in output mode. I’m still unsure, though, whether the pins in input mode can take both positive and negative current, and if so, whether they can differentiate between the two or if it just reads voltage amount.
P
If only - it needs a little more work than that. The inputs are either digital, with voltage above a certain threshold indicting a 1, and below it, a 0, or analog, but only in one direction - 0-12 say. If you apply -12, it will either fry the chip or just not work at all.
You will also need to restrict the voltage to the chip to no more than 5V, so each input will need a voltage divider. Use two pins, each with a diode and voltage divider, each has the diode wired the opposite way. One will turn on if goign forward, the other will turn on if going reverse. You can tap the power anywhere near the turnout for the direction and then use switch machine contacts for the point direction. Now you have your data to compare to activate the approriate signals - you have the direction the turnout is lines, and the directiont he train (should) be going.
If you don;t understand what a voltage divider is - read up on that, there are mentions on many Aurdino forum posts. Google some of what you are trying to do, someone else has very likely already done something similar with the Aurdino. If you don’t understand what a voltage divider is and why you need it, I’m afraid you’ll be frying some Aurdino chips. And they are not as tasty as potato chips.
Arrgh… My posts were sent way after I submitted them. When does the trial period end for new members?
Randy, the voltage divider is a good idea-- I’ll hunt down some bigger resistors. I think I could get away with just one pin, though, since it will read either voltage or nothing, and the binary logic could then set up two different aspects. That saves me from using too many pins as it’s an Arduino Uno and doesn’t have as many I/Os as the bigger chips. There would still be a second diode, but the line would then go through a pulldown resistor and then to ground. Does that seem feasible?
P
Think you’re over-complicating things here.
OK, yes, using an arduino would be fun – but at near $20 per board, you’re gonna be shelling out a lot of cash to wire them all in (unless, ofc, you’ve only got one turnout).
It’s been ages since I’ve bread-boarded things … but there’s gotta be a simpler way with generic off-the-shelf RadioShack parts that’ll end up costing you less per unit than an Arduino. I’ll try throwing something together for you …
Well, the Arduino is already in my possession-- I had it for some other electronic experiments-- so it’s not really any extra cost on my part. But if you’ve got a simpler way to set them up, I’m all ears!
I figure without the Arduino I could use basic diode logic to switch LEDs on a red/green bi-color (three-lead), or a bridge rectifier to keep the red one on regardless of polarity, if I want yellow instead of green. This is fine since all of my lights will either be red-green or red-yellow, no tri-color ones. But then what happens when you switch direction from the controller? The polarity is already used to change the switches, so what do you use to get the other signal states?
What I need, ultimately, is basically something like this crude diagram where there are four states for the signals: one for each direction and each turnout position. The two left signals face left, the double one on the right faces right, and the arrow indicates train path and direction:
<—R----G/R—
R
R /–R/G—
<—R–/
—G-----R/R—>
R
R /-----R/R—>
—G—/
P
COuple of tips for driving lots of LEDs with few pins - LEDs are diodes, so you get the diode logic built in. An output pin can be high or low, so unless you want a ‘dark’ aspect, you cna wire one LED between + and the pin, and one between - and the pin. When the pin is set high, the LED between the pin adn ground comes on, when the pin is low, the one between + and the pin comes on.
You cna take this MUCH further - look up ‘charlieplexing’
As an example, the Digitrax SE8C can drive 32 signal heads, each with 3 LEDs. 4 heads, 12 LEDs, from each 10 wire cable - and 2 of those pins are + and - voltage.
Yes, this greatly complicates the code for the Aurdino, but depending on which one you havem you may not have enough pins to make them all discrete connections. And in any case, if you were going to do that, some simple transistor logic would suffice. For that, there have been many circuit published in various sources - there are some in Electronic Projects for Model Railroaders, and I’m sure there are some on Rob Paisley’s site. They all work pretty much the same way, a set of inputs determines which outputs turn on to light up the proper signal aspect.
there are three parts to your problem:
  • providing an electrical signal indicating the turnout position
  • driving the red/green signal LEDs
  • logic to determine the signal aspect depending on turnout position
with manually controlled turnouts and not having something that routes power to the frogs (like I have), you might have to look at the voltage on the rails to determin the turnout position. This is complicated by the fact that DC makes both polarities possible. An opto-isolator with back-to-back diodes NEC ps2506) allowing bi-polar input would work by monitoring the voltage on the frog and stock rail. In the the one case, both rails have the same voltage. In the other case there is a voltage difference, but because it’s DC it can be either + or -. An Arduino doesn’t help solve thie problem.
i’m not sure what you mean by reversible red/green LED. I think it means the LEDs are wired opposite one another so that the one LED is lit with one polarity, and the other lit when the polarity is reversed. Reversing the polarity is not that easy. Having two separate LEDs would be easier to control since you would be able to apply power to one or the other. In either case, you would like a circuit where a high or low input signal controls the signal. There are 3 terminal LEDs having both a red and green LED in the same housing, which can be yellow if both are powered. Again, an Arduino is no help.
There not much logic needed (where an Arduino could help) assuming you have a turnout detection circuit that outputs a high/low voltage to indicate the turnout position, and a signal circuit that takes a high/low input to control the signal. The signal logic just needs to drive either the red or green signal LED to match the turnout indication. And this should also work find with signals in both directions.
an Arduino could be help
Right – you have ONE Arduino.
Problem is, if you have one turnout over here … and another one 10 feet over there, things get ugly fast (even with Randy’s “connect multiple LEDS to one set of pins” setup).
The other (awful) problem you’re going to run into is the variable input voltage caused by the fact you’re (as I understand it) trying to drive it off the power leaving the pack (or at least use that as an input) – which means that you’re going to be putting in somewhere between 0 and 12 (or 14?) VDC into the circuit.
Now, I’ve got one that doesn’t care about input voltage (at home, apparently forgot to put it on the internet - oops). I’ll put it up later so you can see what I came up with.
edit – nope, I just put them on google:
Through Route
Diverging Route
The SPDT switch can either be your throw itself (IIRC, Caboose Industries has some like this), or if you’re using piano-wire pulls through the facia, then drill a hole through the switch and put your linkage through it.
12VDC is simply your typical lights/accessories bus, and the 1K Ohm resistor is to drop the voltage so you don’t blow the LEDs.
Randy, thanks for the tips and leads. I looked up the signals on Rob Paisley’s site-- I’ll have to look closer, but the simpler ones seems to show some promise. I’ve been looking up using shift registers to run multiple LEDs-- with an outside power source to boost current and protect the Arduino, it looks like it could work very well for what I want.
Greg, turnout position will be indicated from the frogs, which will be powered via the Caboose Industries throws Dan just mentioned. I’m confused by your circuits, though-- wouldn’t the signal circuit and the turnout circuit have to interact, since both determine together which LED should come on? And I’m still fuzzy about how this works if direction switches, because then turnout polarity is reversed and high/low becomes low/high.
Dan, I’m not sure I understand why I would need multiple Arduinos to run multiple turnouts this way. I should point out that the layout itself will be quite small (6’x9’). There will be just 8 turnouts affecting signals, but a few of them will be positioned such that the polarity of two frogs will determine which signal changes from its default of red (e.g. when two turnouts diverge off the main in quick succession). The Arduino would then get 9 inputs (8 frogs + direction) and a further three pins could be sent to a shift register series to drive the LEDs.
Only one of the LEDs will change at a time, because only one path will be allowed based on the direction/frog polarity variables, so it should be possible to either use the Arduino in ‘if-then’ logic to sense the direction and turnout inputs and turn on/off the correct signal LED, OR to use diode/transistor logic to do the same thing without the Arduino. I’m new to this stuff and just can’t clearly visualize it yet…
You’re right, though, about the variable voltage that would be coming into the Arduino-- all 9 inputs would be VDC, and I think that’s why I was having such a hard time figuring
Sorry, i forgot that you said this was DC, and yes, a turnout position circuit could directly drive a signal circuit (san Arduino).
I assume you will have a signal circuit that properly drives the LEDs based on a single input (see below). I assume there are four signals.
it’s not obvious how you plan to determine turnout position from the frog.
i tried describing how by comparing the votlage between the frog and either of the stock rails. there are three possiblities, +/0/-. 0 volts between the frog and stock rail means the frog is at the same voltage and the points are aligned with the other stock rail. +/- means the points are aligned with that stock rail and the polarity indicates the direction of travel on a DC system.
a single-LED opto-isolator could be used to detect a particular turnout position and direction. 4 opto-isolators (or something equivalent would be needed to all four possibilities. each would control one signal. two would be connected oppositely across each stock rail and the frog.
because opto-isolators typically have a simple transistor output, the LED drive circuit can have an input that is pulled high by itself. The opto can be wired into it to pull the input low which should turn on the green aspect.
there should only be one condition where an opto is active: when ther voltage across the frog and stock rail is not zero and of the correct polarity to match
Thing is, that’s making the wiring overly complex, not to mention needing to putz about with programming the arduino in the first place.
Even though the train is running “the other way”, you can still have the other LEDs on. Actually, this is closer to how the real railroads do it (you always know the position of the switch from either end (regardless of which direction you happen to be heading).
I think you’re misunderstanding what I did.
The input power to these circuits is completely disconnected from the track power – you’d use (for example) a 12v “wall wart” that provides a constant 12vDC to a separate bus that these circuits (or lights in structures, etc.) are attached to – typically this is called “Accessory Power” (Many DC powerpacks have connectors for this, but using them means you have less power available for locomotives).
This is LOADS easier than trying to putz about with voltage regulators (and other
four opto-isolator circuits can detect the turnout position and direction. This depends on DC power being present, meaning the signal is red when the DC power is insufficient to be detected. (not sure signal aspect should depend on direction).
I don’t know about a circuit to drive the signal LEDs, except to assume that pulling an input low should be adequate. an NE555 circuit could be used to detect the opto output and drive either of two LEDs. Of course an Arduino could be used, but would be overkill ($20 vs $1+). (you need to use the riht tool for the job. I write embedded RF SW for Qualcomm)
bear in mind that high/low (1/0) typically means Vcc/Gnd, not +/-. The opto circuit translate a +/- into a 1/0.
Greg, that looks interesting, how does it handle the variable input voltage? I mean, you’re gonna be between 1 and 12vdc (or whatever a dc pack puts out), depending on speed of the train. Wouldn’t that cause some degree of havoc with the circuits you’ve drawn?
That’s what the optoisolators are for. Basically electronic switches. The resistors control the current that gets to the optoisolator’s LED, once it gets past a certain threshold, it turns the transistor on, lighting up the signal LED. So they probbaly won;t light up if you just crack the thtorrle, but at full throttle it won;t exceed the limit of the optoisolator. Choice of resistors depends on the spec of the chosen optoisolator.
At this point, it really is MUCH simpler just to use switch machine contacts. If you aren’t using switch machines with contacts (ie, Tortoise), just rig a microswitch that contacts the throwbar or some part of the mechanism. If you need more contacts to activate all the LEDs, you can have it trigger a low power relay. But with SPDT contacts and a bipolar power supply (+V, -V, and ground) and some plain diodes, a single SPDT conact can do what you need.
Thanks Randy!
So essentially, if he’s running his signalling off the track power, it won’t turn on til (for example) he’s hit 5 or 6 volts coming out of his powerpack.
On top of that, assuming each circuit burns 1.5V and 100mA (again made up), he’s going to see lower top speeds out of his locomotives and/or the powerpack won’t be able to power everything that’s running… right? (ugh, I really have to brush up on “how DC series and parallel circuits work”.)
randy’s correct, both with his analogy to a switch and that having a micro-switch tied to the turnout control is probably simply. (I don’t think the signal aspect should depend on direction).
but the signalling doesn’t need to be off track power (even if they had a common ground). Any diode needs at least ~0.7V to conduct. with the resistor something > that is needed to turn-on the opto transistor. But that transistor can be connected to an entirely different power system (wall wart) which is not affected by power to the track.
does anyone have a simple circuit that controls 2 LEDs with a single input?
Something like what I posted before?
input is 12VDC (wall-wart, etc), runs through a SPDT switch to light 2 (well, 3) 2-color LEDs based on whichever way the switch is thrown.
As drawn, it’s manual (e.g. linkage to knobs on the fascia, or Caboose Ind. ground throws with contacts), though I’m sure a switch machine’s contacts could be used instead.
