I have one Atlas GP-7 and two GP-9’s that I want to get decoders installed for. On Digitrax’s website it says to use the DN163A2 on them but the decoder will not fit at all into these loco’s without some serious frame modifications (so much for PNP).
Is there any easier way to do this without having to get a different decoder and hardwire it in (which I do not feel like doing)?
And would someone be willing to put them in for me? I am not that good with the small wiring, and I would have no problem shipping them wherever and paying someone to do it for me. (I live in Alberta, Canada).
Atlas has changed the design of the GP 7/9 a couple of times over the years. It sounds like you have an older version.
The simple identifier is whether the headlights are mounted on a single board across the top of the frame, or in two separate boards, fore and aft. It sounds like you have the latter.
The TCS CN GP is your best bet. I’ve put in a scad of these, let me know if you need any guidance.
I got one of the decoders and installed it into the GP9. The light comes on but the loco won’t respond to any throttle movements I make. I did program the decoder and it did accept the CV for the 4 digit address.
Check your connections to the motor (the orange and gray wires) to make sure they are A) secure and B) not making contact with the frame. Try doing a “read” of the decoder properties on your program track, with the shell off. If the motor appears to “tick” while the readback is underway, it should work.
It’s also possible that during re-assembly, you got something in the gear train out of whack, and the drive is binding. If the engine makes a little bit of noise, or even if it doesn’t, this could be the case. Beware not to overheat the motor if this is the case.
Try taking the frame apart one more time, inspect the drive train and the motor wire connections, and also, (this is important) make sure the wires all have someplace to be. I usually cut out the top tab over the DC motor contact to make a little room for the wires to come up through the top. Having the wires bunched up will cause the frame to mis-align, and therefore cause a bind.
