DCC Engine overloading on DC Track
Hello, I am new here and new to model railroading also. I have an engine with a DH123D HO Scale Mobile Decoder. I am currently waiting for my super chief to arrive so I do not have a DCC system to test with. I ran this DCC Engine on a DC track just fine, then I placed it on another track and the engine seemed to not be able to go at full throttle and stuttered a bit. Then the engine stopped and the overload light lit up. I took the engine off the track, investigated the track and engine for debris and found nothing. I place the engine on the track again and gave it throttle and the overload light lit once again. I removed the engine body to look over the wires and everything seemed to be fine. I placed the engine on the track and gave throttle once again to see the overload light lit. I removed the engine once agian and I happened to touch the decoder and it was hot. Other engines seem to run fine on this track with no problem of overloading. I do not have access to another track at the moment so I can not test the DCC engine on another track. I was just wondering if anyone has had experience with this issue and could maybe shed some light on it for me. thanks for any info, Matthew
Welcome to the forum Matthew. Try asking this on the model railroader forum. That’s the one for model train stuff. And I wouldn’t keep putting power to the loco till you figure out the problem (sound like the decoder is bad) as you may do more damage.
ok, thanks for the reply. I started looking around the forums and noticed that I may have posted in the wrong forum. I just didnt want to double post. mod/admin: please feel free to remove this post. thanks Matthew
