I was at friends today and we put a TCS T4X plug-n-play into a Athearn Sd40T-2. I rewired the cab headlights with 2 470 ohm resistors to the hole next to the green wire. Now for the fun part when my friend programed the engine with decoder pro the Gyra light would only work when the headlight was off. When you turned on the headlight the gyra light went out. We both checked the wiring and it looks OK but we cannot get the headlight and the gyra light to work at the same time when the decoder is in the engine. When I put the decoder on my Loys Toys decoder tester the decoder worked perfectly the led for F1 flashed with the headlight on and did not turn off when the healight was on.
Now for the question am I looking at a hard wire job because the Athearn board has a problem?. It would be pretty easy with the way it is set up now I have done a few blue boxes and they all worked right and I think the new wiring system will make it easier.
Thanks for the help.
Scott O’Dell
