I have a question about the maximum run speeds that a Centennial (DDA40X) would attain on straight and level track.
I have done a bit of a search and have found that the maximum speed for the locomotive would be 90 MPH.
My reason for asking is that I have downloaded one into my train simulator and with the throttle in the first notch (no load, only the locomotive) it attained maximum speed. Would this be correct?
Pointers to any web resources about the locomotive with this sort of detail would also be appreciated.
I’m sure there are forum members who can provide you with better information but I recall reading in an issue of “Diesel Era” magazine which featured an article about the Centennials that they were regularly operated at 89 MPH in fast intermodal service.
UP had FRA permission to operate hotshot freights on the transcontinental line at Passenger train speeds, 89 MPH being the top limit.
The RR also acquired a fleet of SD40-2s with higher than standard gearing for operating at those speeds (nicknamed “fast forties”) and thses freqeuntly ran in consist with the Centennials.
That is in part an artifact of programming – in practice, I believe you would only have the Run 1 engine horsepower available – someone like carnej or M636C probably knows exactly what that is for two E-series 645s – and I believe automatic transition is disabled at that point, so back EMF would pose significant impediment to both higher speed and further acceleration at high speed.
You could calculate how many hp/kW it would take to accelerate the mass of a Centennial (gear ratio 18:59, or 59:18 as some railroads expressed it) and then see what run you’d need to be in to develop that amount of power net of system losses.
As mentioned in another recent thread: a big issue with achieving top speed with a single locomotive is the difficulty in subsequent braking. With only 8 axles and 270 tons, things might be more interesting than with plenty of shoes in the train. (You can see this effect with other locomotives, notably large restored steam locomotives, which will run testing with an attached ‘rake’ of something like spine cars to provide the appropriate extra shoes and contact patches. You could also see this effect rather dramatically when GG1s started to be run on Metroliner schedules with lighter Amfleet consists…)
I am not an authority on programming rail sims – but there are plenty of knowledgeable people over in the modeling forums who are. I would ask them precisely how the code you have could be tweaked or improved.
As for the ‘train simulator’ Centennial’, reaching it’s top speed in run 1 doesn’t seems very real. Maybe the ‘engine file’ (a file that terminates with the extension . ENG) is not well programmed.
As for the ‘higher speed’ SD40s, I think their top speed was 83 Mph. These engines also differ from standard SD40s, since their noses are bigger than normal, to accomodate cab signal equipment, wich means no Front Porch. I don’t know if any of these units is still in the roster
The “Fast 40’s” (8000 series SD40-2’s) were numbered into vacant slots in the 3000 series when they were re-geared back to 62:15. They may still be in service under their 3000 series numbers, rebuilt as SD40N’s (1500-1700 series) or sold to shortlines and regionals.
Or maybe 120 mph, or maybe 200 mph. Timetable limit for freight was never more than 70.
FRA used to say class 5 track was 80 mph maximum for freight, and class 6 track was 110 mph, freight or passenger. Where did the 89 mph limit come from?
Centennials were always 59:18, weren’t they? So EMD would say they were good for 82 mph or 89 mph, depending on what year you’re in.
Starting with the D47 traction motor(1958/59), EMD raised the maximum rotational speed of the motor. With 62:15 gearing, old GP9’s had a maximum speed of 65 mph. With the D47 in a GP18 or GP20 - That same gear ratio resulted in a maximum speed of 71 mph. With a D77 or D87 traction motor in the 40 or 50 line of locomotives, and a 59:18 gear ratio - 88-89 mph is about right. The key here is that with a heavy current load through the traction motor, the copper winding heat up and become ‘soft’. The high centrifugal over-speed could cause the windings to creep to the outside of the case and ‘ground short’. Even running at a lower speed for extended time with a high amp loading; the traction motor can ‘bird cage’ and cause a ground short.
A “squirrel cage” is a kind of inductively coupled winding in a type of AC motor. A “bird’s nest” is what an overspeeded DC motor turns into – centrifugal force scrambles the rotor windings so the resulting tangled destruction looks like a bird’s nest of interlocking grass and twigs.
An AC motor, by the way, cannot “bird’s nest” as its rotational speed is limited by the supplied AC frequency.
So I am thinking the slangy technical terms is “bird’s nest.” Yessir, I am an Electrical Engineer.
I believe the actual technical term (at least the one I always remember seeing) is ‘birdsnest’ (one word)
AC motors cannot birdsnest because their copper is in large, stout bars, and you would have to spin the armature VERY fast indeed for the resultant that is ‘centrifugal force’ to pull them out far enough for stator contact.
And it should be remembered that, just as an inverted spin doesn’t cause the major aircraft damage, the ground contact does: A certain amount of ‘centrifugal’ winding expansion is normal, and wouldn’t cause substantial damage right up to the yield point of the windings (or where the insulation cracks off enough to produce shorting). It’s the contact with the hard, unmoving pole structure that does the business – and causes the shredding of insulation and then conductors that makes the term so evocative. And since the gap between armature and pole is kept as tight as possible to minimize the air losses – only a slight amount of overspeeding, even with Kevlar bands or whatever trying to keep the windings located, may start the evil process…
Something that might be mentioned here is that even slight contact of armature winding with pole is going to scrape off the insulation and produce a rather massive short. If you think about what happens after that, to the expanding and melting copper and what-not, you will add interesting and exciting new details to the birdsnest-development scenario…
The reason for minimizing the air gap is to minimize the reluctance (inverse of magnetic permeability) of the magnetic circuit driven by the field windings. Lowering the reluctance reduces the number of amp turns to generate a given field strength, as the torque produced by the motor is proportional to the product of the armature current and field strength. OTOH, the maximum field strength is limited by saturation of the iron in the pole pieces and motor frame.
FWIW, the Milwaukee used steel wire to bind the windings in the armature slots when the original GE locomotives were rebuilt in the 1950’s.
They were geared for 80mph, there was a set of SD40-2s geared to run with them in the 8000 series, the famed “Fast Forty’s”. Railfan and Railroad had an article in 1980 (or '81) about chasing these sets through Oregon’s Blue Mountains.
