if the engineer needs to leave his seat when the pedal is active, does the second man in the cab have to press the pedal on the fireman’s side first so the engineer can stand up without dumping air?
can engineers eat as they are operating the controls on road jobs, or must he ‘retire’ and let the conductor take their place?
when is the pedal active, anytime the engine moves?
will the engine move from a standing start if the pedal is not pressed down? are any locos exempt from this system?
it seems rcl nullifies this concept in yard work… a conductor can get hurt the same as anybody else: he/she can fall; have a heart attack, a stroke, slip getting on/off a step, daydream, etc… 2 people in a cab can back each other up watching for danger inside and outside the cab, but not anymore… as cars take heavier, more valuable and hazardous loads, it seems there is less concern for crew safety… also, is r-o-w maintenance what it should be? csx was recently cited for poor track p.m…
if the fra is citing r.rs., is that just for the public’s benefit? is there worse going-on that’s not being discussed?
in reading history about r.rs., it was common for workers to miss fingers and hands from pulling the pin before auto. couplers… workers also died in braking cars before air brakes…
back then, it was primitive technology and many workers on-the-job, and many died or were maimed… nowadays, it’s advanced technology (at least in signaling, communications and tracking engine usage), but fewer people, and the danger level is the same or worse…
when i first became interested in r.rs., part of it was being part of a team, where everybody knew the team and how everybody worked… now, it seems the rco is often alone, and lucky if he is paired with someone he already knows… and that’s scary… if you don’t know your partner, how can you be sure you and he are on the same page when it comes to recognizing danger before it happens, or wh
