decal question or experiment
I need a stripe color that is not standard decal. Color matching with printing is tough, and even then it still might not w ork to print it because of the problem of printing and transparency. Has anybody taken white decal blank paper and sprayed on a solid color, then cut it down into decal stripes? Or I am I going to be doing an experiment?
Shane
I just mask it and shoot the stripes with my airbrush.
I used True-Color paint and my cheapo Harbor Freight airbrush for that E7 with a combination of Scotch-Blue Delicate Surface 2080 tape and 3M-471 Automotive striping tape.
Works great.
Mel
My Model Railroad
http
Tamyia also makes a great tape for masking curves. You can get it in different widths,
Mike.
While I often mask-off areas on newly-lettered freight cars before weathering them to create “new-looking-areas” of paint, which will be used to add re-weigh and re-pack data to cars like these…
…I also paint clear decal paper with various shades of boxcar red/brown and also with black, as with the re-pack data shown on the two cars above.
Here’s one with the patch of black-painted decal applied…
…and with the lettering added…
The problem with these airbrushed decals is that even strong decal solvents, such as Solvaset, have a tough time softening the painted portion of the decal - the decal film responds to the setting solution, while the paint does not.
I’d think that the results would be even more noticeable for striping.
Mel’s suggestion of masking and painting the stripes is a good one, but be sure to use a good-quality masking tape, as Mike suggests.
I recently painted two Athearn coaches, to be used as trailer cars for my doodlebug, “The BEE”. The results were less than satisfactory, as I used my regular masking tape, with all factory-edges trimmed off, but the plethora of small rivets on the cars’ sides allowed an inordinate amount of bleed-under of the black paint, resulting in a lot of brushwork to make t
Try the 3M-471 automotive masking tape, it really takes great to rivets and seams. It doesn’t pull the paint off even after applying a lot of pressure to make sure it seals good to the surface. It comes in several widths, I stock both ⅛” and ¼”.
It also curves easily as in the SP deep V.
Mel
My Model Railroad
&nbs
Beautiful work, Mel. That paint job is gorgeous! [Y]
Thanks Rich
This is what it looked like out of the box, I bought it off eBay as junk.
I let them set in Denatured Alcohol over night and with a bit of elbow grease and a stiff brush they came out very good.
Mel
Beautifully done restoration Mel.
wayne, did you do masking over paint to help stop bleed On the Bee?
i have the Tamyia masking tape. Didnt know automotive masking came so narrow. I will have to look. Does it come in 1/16th which is what i need. I dont do well at masking straight lines. On my NVSRR the stripes covers the mask line between the blue and grey. I can get a decal much straighter. I was also just curious if the idea would work. Model flex is suppossed to be a flexible paint though.
lastly. Why does paint shift color when sprayed vs brushed? I find that a lot when touching up an airbrushed color
shane
The BEE was done quite a few years ago, and I experienced little in the way of bleed-under using regular masking tape.
The Athearn cars’ roofs were masked to paint the sides and ends yellow, then after the yellow had dried for several days, I used ordinary masking tape to mask for the stripes.
To keep them straight, I put ordinary masking tape onto my glass work surface, then use a sharp blade and straightedge to remove both factory-edges of the tape. This gets rid of the dings and dents, and the fuzz that collects on the edges of the tape, and the not-quite-as sticky-as-it-should-be adhesive (due to exposure to air) near the tape’s edges.
To match the BEE’s stripe spacing, which is on a former Rivarossi car, I determined that the uppermost stripe needed to be on the Athearn cars’ rivetted belt line, right below the windows. That stripe is 1’(HO) wide, with a 3"(HO) space between it and the line below, which is 6"(HO) in width.
With another 3"(HO) space below that, the bottom stripe is 3"(HO) in width.
Starting at the top of the pre-trimmed tape, I cut the tape into eight 1’(HO) wide strips, placing one at the top of each of the belt-line rivet battens, then using my fingnail to form it over the multi-dimensional profile of the battens.
This naturally left the width somewhat less than one scale foot, so after determining where the bottom edgeof that stripe should actually be, I applied the second pre-cut 1’ strips to fill-out the missing width, overlapping the first-applied tape.
I followed that, on all four carsides, with an application of 3"(HO) tape (to represent the black space which would be between the yellow stripes), then added the 6" tape, followed by another 3" spacer and the bottom 3" tape to cover what was to become the bottom yellow stripe.<
I had some 1/16” several years ago and it worked very good. It wasn’t 3M but I bought it at a automotive paint supplier here in Bakersfield. ⅛” is the smallest 3M vinyl masking tape. I keep a roll of ⅛” and ¼” on hand.
Mel
My Model Railroad
Bakersfield, California
I’ve seen a “how to” article (I think in MR) where somebody took one of Microscale’s solid decal sheets (where the entire page is just one color) and cut it into stripes. Can’t see why what you suggest would be all that different, except that you’re creating your own solid-color decal page?
Inkjet printing will bleed unless you seal it before applying. So, if you are cutting the decal into thin strips, you will need to cut first, then seal because otherwise the stripe edges will bleed and mess everything up.
I’ve had success both with masking and spraying and with making stripes with decals. I have always planned it so I could apply dark stripes to light surfaces.
