Does any company besides TCS use the keep alive capacitor concept with their decoders?
All the major decoder manufactures have their own version of the keep-alive. They just call them by different names.
And I’ve used capacitor packs from different manufacturers on other manufacturer’s decoders. I bought several of the Broadway Limited ‘Go Pack’ caps and then decided not to use their decoders but I installed the caps into WOWsound TCS decoders at a later date with no problems.
Several manufacturers are integrating the keep alives right in the same board with the decoder.
Good Luck, Ed
Ed, I’d be curious to know how you can combine parts from different manufacturers.
I use Digitrax decoders these days, and you can add a fairly low-cost capacitor from the same company (they call it power extender). I installed one just this week and it seems to be working properly. Total cost is very reasonable.
Simon
Hi, Simon
In some installs I use a Decoder Buddy which has pads to tap into the U+ and ground. Those are easy to wire any ‘keep alive’ to. I have some TCS motherboards made for Genesis F units with a 21 pin plug but I put ESU decoders on them. No problems. I used the Broadway Limited GO packs on TCS WOWsound decoders. As long as the polarity is observed they all pretty much do the same thing. As far as I recall only the ESU capacitor has the third wire which can effectively switch the keep alive off for programming purposes.
While this photo shows a Soundtraxx decoder and cap, I could have used other makes in either position:
NYC P-2b 237 motor by Edmund, on Flickr
Good Luck, Ed
Thanks!
the keep alive is not really internal to the decode, it’s wired across the rectified outputs of the diode bridge
I see that. The decoder buddy would definitely make it easier.
Simon
