Delaware & Hudson 350 "Transit"
Does anyone know where I can find more information about the Delaware & Hudson inspection locomotive #350? So far I’ve found this page, which lists the build date and number: http://alcohistory.blogspot.com/2007/06/delaware-and-hudson-350-transit.html
Any more information would be appreciated, but especially dimensional info and paint colors.
It would appear that information on 2-2-4T “Transit” is as scarce as hens’ teeth!! It doesn’t seem to even get a mention in the D & H Historical Society website rosters, though neither does the 4-4-0 inspection locomotive “Saratoga”.
The only dimension which I’ve managed to find which would be of any use to a scratch builder is from Jim Shaughnessy’s “Delaware & Hudson” book and that is that the driving wheel circumference of 54 inches. However, the information also indicates that the “Transit” was rebuilt in 1922, and given a 56 inch driving wheel. It also gives the disposal date of 9 September 1933.
I would suggest that the two photos that you have got, are of the original build “Transit”, and from a scratch builders’ perspective, you have huge advantage of having a view of both sides and ends!
The window pitch is wrong but I’m wondering if the Roundhouse 34’ Old time Overton Coach would be the basis for a build for the body?
Just to muddy the waters, are you particularly “stuck” on the “Transit”? I only say this because if your interest
Thanks for the information. I had anticipated that info would be pretty sparse. Not sure if I want to go forward with trying to build it, but at least with a known dimension I can make reasonable guesses.
