Does it suffice to declare that an emergency brake application by itself will not cause a derailment; it’s what happens to the train before and after.
All, but one, or two, scenarios provide for desired emergency function.
air hose separation, broken brake pipe or knuckle, coupler failure, derailment, eng crew in fear of getting killed in a collision, trespasser uncoupling a stopped train----all desired emergency apps.
After any of the above there is no control, except for the obvious “OH SHI…” application, of the brakes and thus stopping or securing the cars when stopped. Gotta’ have the emergency app.
What caused any of the above caused the app, and then track profile, train make-up and train handling good or bad luck caused the derailment.
un-Desired emergencies…here are three:
After coupling to a train and the air’s been cut-in the pre-charged trainline, got to change ends. When in the cab at the other end of the engine consist, the brakes have been charged by the car’s brake valves emergency release function. If the engr’s brake valve is cut in before the equalizing reservoir pressure matches or exceeds the brake pipe pressure…bloooey.
Another…After doubling over a big cut to a joint, the (explitive deserved but deleted) train or yard crewman opens the brake pipe’s angle cock too quickley causing a brake pipe pressure reduction rapid enough to trip an emerg, app.
Most common real UDE was a car brake valve that mechanically hung-up during the (relatively slow) brake pipe pressure drop initiating a train brake app. and after a substantial pressure drop moved causing an emergency app. rate of brake pipe pressure reduction enough to trip emerg. actuation there and then transmit a train length emerg. app.
.Let’ not mention the broke-in-two trains stopped a few car length’s from a STOP signal…"broke in two 'cause of a UDE.
&nb
