Thanks Don. I like the control panel voltmeter idea. Not one for each cab, not enough room, but one extra rotary cab switch will let one meter service all three packs.
The existing layout is wired two rail and working well, so the expansion will probably match.
While a VOM would answer the original question, the idea was to see if anyone here knew, before opening the box. MY LHS is already touchy about returning electrical items, actually returns are expressly forbidden and exchanges, wellllllll…
If someone in thisthread said, “No doubt, the 260 is more powerful, it will drive trains much faster at any given throttle setting”, I would have exchanged it, unopened, for another 220.
Instead they said, “It doesn’t matter, two packs at the splices will surge a loco anyway.”
So I kept it, opened it, and wired it up.
It works perfectly.
Well, almost perfectly.
Perfectly at 30% throttle.
At 60% throttle, the 260 is throwing a little more power. Just a fuzz.
That fuzz is important though.
None of my locomotives besides the BLI ever run at 60% throttle.
Like I tell my son. “Them ain’t slot cars.”
But the QSI sound decoder in the BLI is a voltage black hole. It doesn’t even move till 50% throttle.
At 55%, the BLI pokes along.
At 60%, it goes lickety split.
I probably need to adjust Vmax and maybe Vstart.
For now though, even a slight difference between the 260 and 220 at 60% throttle has large speed implications.
No matter, we’ll have “wandering cabs” after the wiring is done right. We’re just testing now.
If any questions come up then, and I can see the need to be able to cross divisions between power packs in addition to using cab following loco techniques, the voltmeter will give me what i need to make it happen smooth.
Good idea, I appreciate it, thanks.
