Digitrax and programming track
I have a spur that I am going to use as a programming track. It has a “dead zone” that is at least as long as my largest locomotive. I am uncertain how to wire the switch between the dead zone and the programming track. I do not know if I should use a SPDT center off switch or DPDT switch. And which wires connect to what other parts including the power pack. I know that the wires to the programming track have to connect to the command station/booster at the LocoNet port but what else??
The safest way to wire the programming track is through a DPDT center-off toggle switch. Wire the toggle switch center terminals to the programming track. One set of end connections on the toggle go to the programming track output on the DCC system and the other connections go to the track output on the command station. This way, you can run a locomotive onto or off the programming track if you so desire, and the programming track can even be an isolated section of mainline trackage.
Just be sure you keep the DCC system’s main track power output wires the same as they go through the toggle switch. If an engine stalls when you try to run it onto the isolated section, the wiring needs to be reversed.
Are we talking Zephyr/SEB or Super Chief?
David B
Craig,
See this thread, about the 6th post down, where Tom Stage has posted color diagrams of the best way to wire up such an arrangement. It references a different brand of DCC system, but the concepts are exactly the same.
Be sure you skip the first few posts with the black and white diagrams (they were practice! [(-D] ), and refer to the ones in color.
To do it right, you will actually need a 4PDT switch, which isn’t too expensive or hard to find.
HTH,
Steve
