I just bought a Digitrax Chief system that’s been sitting on a shelf for a few years.It’s still brand new,had never even been tested by it’s owner.Just for the sake of testing the system and learning how it works,I assembled a simple loop of track in order to keep any electrical complexity out of the experiment.I then tested the trackwork with DC…no bug at all.
Now I’ve linked my loop to my DSC 100 according to the manual and…so far so good.Every vital signs of the system are what the manual says…no overheating,no shut-down,etc…everything seems OK.
Still following Digitrax’s recommendations,I tried to run a DC loco…but…no run.I know the loco is a great performer(Kato SD-45-N scale,still new),so I tried another known good loco,same results.Even if I repeatedly dial the prescibed sequence,adress being 00,no success.Then I started different sequences for a while when,just before I was about to quit,the DC loco started singing.I then turned the throttle knob and the engine started going,smooth as silk in either direction.
I then tried my brand new factory decoder equipped Atlas Trainmaster with the same results,going silent and smooth,in either direction.Pretty satisfying,although none of the engine’s lamps did turn on at any time.I guess programming will take care of this later.Then it was time to go to bed,so I shut the system off for the day.
My problem is that I’m now trying to get locos running again following the instruction manual but can’t succed.Yesterday I succeeded after tweaking knobs and buttons for a while,out of sheer luck I guess.I try to follow instructions to the letter but that doesn’t work.I know the system is OK so it is a missing instruction in the manual,or a confusing sequence,or…I can’t read english…or what else?
I read through the manuals(system/decoders) and I have a feeling that,even if it probably is a great system,I’m in for some headaches when learning how it works as the instructions often seem somewhat co
