Digitrax UT6 IR Operation Help
Hello, I have a UT6 throttle and a UR90X panel. The IR dialog works correctly, but if I want to change the locomotive number, I have to reconnect the Loconet cable to the panel. Once changed, I can unplug it, and it works correctly.
Can I change the locomotive address without reconnecting the Loconet cable?
Thank you for your help.
Have a nice day.
Selecting a new address with Digitrax throttles requires the D as in Duplex suffix for the throttles and receivers. I started out with Digitrax throttles in the early days and I always had to plug in to Loconet in order to select a new address.
Digitrax quit supporting the older simplex throttles a few years ago. Everything they offer now is Duplex.
Hope that helps, Ed
