Diluted white glue using alcohol
I had read in another thread about making diluted white glue using rubbing alcohol instead of water. When I tried to mix it with the same ratio, 4:1, it turned into a thick goo. I found that mixing it with a 6 or 7:1 ratio it had almost the same consistency as the water mixture. I also found that prewetting the scenery wasn’t as important. This mixture flows right into the ground foam, and it dries much quicker.
I used a roughly 50% glue-25% water-25% alcohol mixture on my layouts, yes the alcohol really helps capulary action a great deal and it evaporates off quickly leaving just the glue/water mix, drying time is still the same but the glue goes right thru to the base which without the alcohol would take alot longer. Some recommend adding a drop or two of dishwashing liquid as well but to my experience its not really necessary.
I have been using rubbing alcohol in place of water for several years, even as a pre-spray for ballast, and believe alcohol is better because it evaporates and allows the glue to set up faster.
What glue were you mixing that caused the alcohol and glue to 'turn into a thick goo." I use plain white glue (Elmer’s or a generic brand) that comes in a gallon jug.
Nice to know, guys. I had my first experience gluing ground cover last night, and I wouldn’t mind a little improvement. I used a 50/50 mixture of Elmer’s white glue and hot water, then dumped in a little 91% isopropyl alcohol. So it was probably close to 98% glue and water to 2% alcohol.
Seems to work OK, but it took a seemingly long time to dry. I may have laid it on a little thick, however. I’m hoping I don’t end up with that infamous glue “shine” to my turf.
Do you spray this solution? I dribbled mine on drop by drop. I was afraid the solution would clog my sprayer, and/or the spray would dislodge too much ground foam.
I’ll try bumping up the alcohol content tonight. In the solution, that is, not necessarily in me.
I use a Woodland Scenics plastic spray bottle. Don’t get too close to the work and it won’t move any but the lightest ground cover. When I am done I just rinse the bottle and spray water through the sprayer until is comes out clear. It works fine.
Yikes, substituting rubbing alcohol for water? I am not surprised that it turns into a thick goo. And a mighty expensive goo at that.
There is no need to add rubbing alcohol to the glue mix. Water does quite nicely.
What I do is to add 4 parts water (cold, not hot) to 1 part glue (I use matte medium, but whatever, Elmer’s Glue is cheaper, I will concede). Then, I add a few drops of liquid dish detergent to aid in the dispersion of the glue mix into the ballast or ground cover.
But here is the key to success and where the use of rubbing alcohol is important. Before applying the glue mix, I spray rubbing alcohol over the area to be glued until the area is thoroughly wet. Using rubbing alcohol in this manner ensures an even spread of the glue mix without upsetting the ballast or ground cover.
Incidentally, the drying time of any diluted glue mix is going to be 48 hours to 72 hours in my experience.
Water/detergent does not work everywhere. My area has hard water and it has never worked for me. Not even using alcohol for the pre-wetting - the glue/water just puddles. That’s when I tried alcohol. It’s not an expensive proposition, store brand 70% isopropyl alcohol is well under a buck a bottle. It seems OK as is on ground foam but for ballast it still likes a pre-wetting spray of just alcohol
For ballasting I have an old mustard bottle that has a small tip - Plochmann’s brand - which gives nice control over how much glue/alcohol mix comes out. I mixed up maybe half a bottle full and it was enough to glue a lot of ballast down. That plus filling up the sprayer with plain alcohol used less than 1/4 of the bottle of alcohol - I’ll need 2, maybe 3 bottlesof alcohol, less than $3.
I use Elmer’s in the gallon jug. Once I got the ratio right, it was nice and thin, and flowed like nobody’s business.
So, what was the “right” ratio?
7 parts alcohol (70% isopropyl):1 part white glue
LOL
That has to be one expensive glue mix.
Next time, try a 4:1 water to glue mix with a few drops of liquid dish detergent added in, and pre-wet the area to be glued with rubbing alcohol. Just try it in a small area as a test and see if you are not happy with the results.
I don’t get the ‘expensive’ part - 70% rubbing alcohol is CHEAP. And the overall whole thing will be a fraction of the price of matte medium. A quart od matte medium, is like $20 at Michael’s. So not worth it, you can buy gallons of glue for that and there is no noticeable difference.
And I repeat, the soapy water method simply does not work in all areas. Funny how in the past year or so the scenery articles in MR have switched from the soapy water to using alcohol.
I have to agree with Mr. Smith on this one. I buy quarts of 70% at Wal-Mart or Target for about $1.50 each and mix it 50% with water in a gallon jug. This goes into a hairspray pump bottle for pre-wetting ballast and ground cover and then also mixed half and half in Elmer’s small bottles and dribbled / poured over everything. That would give you a 50-25-25 mix of Elmer’s to water to alcohol. Usually spread it out before bed and it’s hard but still damp to the touch after work the next day. Completely cured out in two days but I have been known to speed thing along with carefully placed fan-style heaters on a weekend during a building blitz.
Tried the detergent and water mix which worked almost as well, probably just as good for most cases. I use a Highball ballast of N and HO scale limestone and had some cases where the finer N scale ballast didn’t wet out “good enough” before I poured on the glue which makes it roll up into visible lines along the roadbed. The alcohol mix has never resulted in this so I just use it all the time.
Rubbing alcohol may or may not be cheap, but water is cheaper.
As far as matte medium goes, forget about Michael’s and paying $20 per quart, you can buy a gallon of matte medium for around $30 at places like Mister Art and Dick Blick, often with Free Shipping.
I have also used white glue diluted with alcohol.
However, I would recommend using all you mixed within a couple of days.
If left much longer, it will turn semi-transparent in the bottle and will dry glossy instead of flat when used again.
That might be okay if there happens to be a Blick store near you. And when I looked at the Blick website, a gallon of matte medium at the 30% off list price was $61.60.
As long as we’re on the topic, and since I’m in the middle of my first experience with gluing down ground foam, I have to ask: Is it normal for the process to discolor the ground foam, or at least make it darker in color?
That seems to be the case for me. Just wondering if that’s typical. Again, I’m using about 9.5 parts white glue/water with .5 parts alcohol.
It’s pretty much a common occurrence that materials you glue down with diluted glue for them to darken when the glue dries. I use the spice shaker bottles to mix Woodland Scenics ballast (I use light gray) with sand from the sand tubes you can buy at Walmart. Make sure to run a magnet through any dirt or sand. You’d be surprised at the amount of metal that you’ll find. Also, bake it in the oven to kill any “critters” in it.
Thanks for the reply, Marlon. I thought that was the case, but it’s reassuring to know I’m not screwing up somehow!
I’ve never noticed that with either ballast or ground foam, so it may be due to the alcohol.
The only alcohol I use is the drinkable kind, often after an enjoyable session of ballasting or doing scenery work.
