I’ve got an HO steam loco in which I want to install the subject lighting. I’m using d.c. on my railroad. The loco begins to move with a track voltage of 2. For realism I want the loco/tender lamps at full brightness before movement starts. Although I’d prefer to use very small, closer-to-scale size white/clear LEDs they don’t come to full brightness under 3 volts so I’ll use 1.5 volt grain-of-rice-size incandescent lamps.
I have another loco in which I installed this type of lighting and it works very well. In that loco I used a commercially-built lighting circuit that’s encased in a potting compound so I don’t know what components were used. There was no schematic diagram with it either. From review of constant lighting circuits in general I find that I’ll need at least a couple of diodes to light one lamp and shut off the other depending upon the direction of travel of the loco. It would seem I would also need to somehow provide a voltage drop with resistors in a voltage divider circuit to limit the voltage to the lamps to 1.5. Since the track voltage varies, though, depending on the loco speed, a conventional voltage divider circuit wouldn’t work since it uses a constant input voltage level to produce a given voltage drop.
Does someone have a schematic of a circuit that would work, including diode specs.?
Not all ‘constant-lighting’ solutions apply to this situation.
Personally, I strongly recommend that you stick with LEDs, and design your voltage networks and switching around them.
What I think you’re saying you want is to have the lights come on at an ‘earlier’ stage of powerpack advance than when the trains physically move – say at around the nominal 1.5V that the bulbs were rated for. The problem is that to maintain a consistent clamp of 1.5V above that point is going to involve more than simple diodes and a resistance network… think some designs of ESD protection, where any voltage ‘higher’ than 1.5V-to-the-load is shunted around the light to some sort of dissipating resistance and separate ground return, so the effective load voltage is ‘clamped’ at your 1.5V or whatever. A proper clamping diode and some relatively simple circuitry will provide this.
A diode in a usual light board may be more than just the ‘one-way switch’ that enables default directional lighting.
A potential issue is that it may be hard to source clamping diodes (e.g. Zener or Schottky) with a voltage as low as 1.5 but adequate ampacity for the bulb starting loads. Most uses for these are as voltage-controlled references at 3V or above, which for your purposes are worthless if the train moves by 2V…
Resistors only reduce what goes through them. To get them to approximate “1.5V” over the range of speed increase, presumably up to 12V applied to the track, would require some sort of voltage-controlled switching to multiple resistors or taps in a resistor ladder – not simple, not cheap, and still showing stepped brightness. Theoretically yo
Back in my DC days I installed several of these in locomotives. Circuitron made kits back then. I had a diagram of one written on the back of an envelope but I lost that long ago.
This gets a bit confusing but I’ll give it a shot.
I did this with all my locomotives before DCC. Back then I used 4 diodes in series parallel for each locomotive. Two diodes in series have a 1.4 volt drop. You put a pair of diodes in series with the motor and the 1½ volt GOW across the diodes. This drops the motor voltage by 1.4 volts.
The single diodes above have .7 volts drop across them, put two sets of diodes in series with the motor and you will have constant 1.4 volts continuously across the diodes in ether directions after the locomotive starts moving. If you want the bulbs to be directional You will have to use three sets of diodes in series for a 2.1 volt drop to the motor and diodes in series with the bulbs.
Three sets of diodes in series with the motor (.7 volts drop per set of diodes) and .7 volts drop to the bulb.
Overmod- you mentioned that “Randy” is no longer with us. Sorry to hear that. I’m pretty sure it was he, a couple of years ago, who suggested some circuits for speed control (“throttles”) using d.c., one of which I put together and have been using ever since.
Ed- you said you used commercial kits by Circuitron. The “black box” one in potting compound I have was made by Hobbytronics a couple of decades or more ago. Think they’ve been out of business for a while now. Could be similar circuit.
You and Mel point to circuits using only diodes to drop the track voltage to ~1.5 for the lamps. Guess I need more insight into solid-state electronics to understand how that works. I “came up” in the vacuum tube days of the '50s and '60s before solid-state had taken hold in the “general” population!
i believe you’re looking for a current limiting IC that can be put in series with the LED replacing the resistor. like the resistor, it limits the current. but unlike the resistor, it maintains the current even as the voltage increases
That circuit works good and is simple. It does lower total and available motor voltage a bit.
Not sure what throttles you are using, but, the best DC motor control is full voltage high frequency pulse width modulation, like the Aristo Train Engjneer or several other throttles on market from people like Ken Stapleton, search Kens Model Railroad Electronics.
The side benefit of PWM throttles is that lighting circuits see the power as full voltage as soon as any voltage is on the rails, lighting the circuit before the loco moves, almost every time with almost every circuit design.
Using this throttle takes care of having to wire each individual loco. Its the basic version of Sheldon’s Train Engineer he mentioned. Incandescent light bulbs illuminate to full brightness before the loco starts to move.
Wire the small box in between the track and the power pack, and then use the tetherless, wireless, throttle. Its always nice to have a wireless throttle.
Hard to find these days but they do appear on the market once in a while.
The lamps see the full votage pulse and light full brighness, any flicker from the pulses is so fast your eyes can’t see it.
That is the simplest explaination.
The lamps are a resistive load, it still takes time for the load to colapse when the voltage is removed, by the time it starts to colapse, the next pulse is there.
The motors on the other hand are inductive loads, so they see the pulses as “average voltage” maintaining the the field current. So the pulse width determines motor speed, but the pulse makes the motor resist stalling and have a lower possible slowest speed.
Here is a picture, not a great on, of the Train Engineer throttle I use. It too is a base station throttle that requires no recievers in locos, but this one has 10 channels for multiple throttles on the same layout.
Here’s the basic circuit I used for years when I was still running DC. Should be self explanitory. Constant / directional lighting for 1.5 volt bulbs …
When you install the TE, the DC power pack is set to full throtttle. Because the TE is installed between the PP and the track, the TE calibrates the voltage that gets delivered to the track based upon how you throttle it up or down. I don’t understand PWM modulation, but the “spectrum” of the voltage that lights need gets delivered full power because your power pack is set at full throttle, while the motor needs the other part of the spectrum to start moving, which it does as you continue to advance the TE throttle. Putting it into terms I can understand.
As background: The old Life Like Protos used to have a bunch of “resistors” (some other do-dad that escapes me) on their directional light boards, to hold back power to the motor as the light began to illuminate at slow speeds.
You could sort of get the bright light effect before the loco moved with just a DC power pack (and moreso if you switched to LEDs), but many complained about that slow speed lighting feature because the loco would then run considerably slower than other brands. And LL seemed to change the lighboards every six month run so locos were not real consistent with each other if you had some from various runs.
I assume this phenomenon would also happen if you built your own directional light circuit and i
because the lamps are resistive, no voltage means no current (V = IR). it doesn’t take any time for the “load to collapse” as with inductive loads. (inductive loads resist changes in current).
with PWM, both resistive and inductive loads see an average voltage and power (the power supply certainly does)
however, the resistance of incandescent bulbs increases as the bulb gets hot and i assume temperature and resistance will be lower (i.e. more current) even with partial voltage
using pulses, like pulse width modulation (PWM) is a common way to control the brightness of LEDs. AC dimmers work on the same principle, delaying the start of each AC cycle and power to the bulbs even though the bulb my see peak voltage
you may be right … but i don’t agree with the explanation.
That, of course, is a kludge. And not a very skillful one, either.
There are a couple of types of ‘PWM’ as the term might be broadly applied to DC voltage control. We might start by trivially noting that typical model-train motors run more quickly when fed a higher voltage, but make shaft torque/‘power’ in proportion to amperage. Likewise that increasing voltage to an incandescent lamp of fixed wattage rating will make it burn more brightly.
If we take DC current and interrupt its flow periodically during a particular time, the effect will be as if we decreased the overall voltage. We can do this as the kind of “PWM” in DCC modulation, where nearly the full DC supply voltage is available most of the ‘on’ time (this is what is meant by a ‘square wave modulation’) or we can do it with half- or full-wave rectification of sinusoidal AC potential followed by SCR/GTO gate-controlled interruption of part of each of the rectified half-cycles, before or after the voltage has reached ‘full’. The result is effectively a lower average voltage, but possibly relatively high voltage at part of each rectified half cycle. We also note that the (brief) peak voltage in the rectified sine wave is greater than the ‘average’ voltage, a point that becomes significant later.
For practical electronic reasons the easiest way to build a device to do this kind of ‘PWM’ is to have it reset itself to conduction when the driving voltage goes near or to zero, which occurs 120 times a second for full-wave rectified house power.
Now consider what a capacitor does when looking at a ‘chopped’ pulse from this sort of device. It charges very quickly depending on instantaneous voltage, so if the applied pulse goes up to &
Doughless
For a DC guy with a PWM throttle, those LL P2K lightboards were great, but it did take a few extra notches on the throttle to get them to move.
A ‘kludge’ is an inelegant, but operationally functional, ‘solution’ to an engineering problem – though ugly to technician eyes, it works after a fashion. (There are less polite terms for ‘solutions’ that don’t work right or fail purpose… [;)])
What we’d need to see is how the Train Engineer produces its modulated output, and what the electrical characteristics of that output are. That will have a direct bearing both on the kinds of ‘light board’ the OP might use and on the various alternatives to get better lighting appearance that he might use if he adopts the TE solution.
If the electrical explanation of PWM is too arcane, I can do the ‘garden hose’ version I use teaching STEM students…
I don’t have the time or the energy to debate why or how this works.
But it does.
A few base line facts.
The Aristo throttle uses a pulse rate well above 60 cycles, I’m not home where I have that data, and per Mr Einstein, I don’t memorize stuff I can look up.
It also has a very clean square waveform, decades ago several of the large scale guys scoped the output.
I know this, 140 different locos, steam, diesel, most made in the last 30 years, different brands, different lighting circuits, some homemade, many factory lighting boards, none with DCC decoders, all work pretty much the same on the TE throttle.
The TE throttle uses push buttons and has “steps”. One or two quick taps steps you up enough to light the lights. The locos typically require about 5 steps to start to move at a speed between one and three scale mph, depending on the loco.
Some lights eventually get just a little brighter by half throttle, but I would say all are above 85% brightness when they come on and with many there is no change you can notice.
1.5 incandescent or LED seems to make no difference.
And I have allowed locos to idle with the lights on for periods as long as 20 minutes with no motor damage.
Of course, never confuse inherent archane-ness with “simply too uninteresting to pay attention”, now that you’ve reminded me about some classes I have taken a long time ago. [:$]
