Been doing N scale forever and have decided to also do an HO layout… Question is how far apart do most people space the track in yards and sidings… Will be a single track mainline so not worried about that…
On straight track, the minimum is 1 and 13/16 inches and the “norm” is 2 inches, but some people like more principally for greater access.
The separation needs to be more than 2 inches for almost all curves, dependent on the equipment and the radius. See NMRA’s website for recommendations.
I agree in principle with the statement that one should consider the NMRA specs seriously. And yet, there really is no substitute for ‘field testing’ your own circumstances and preferences.
Suppose, for example, that your widest curves are in the 24" range and the specs say to have 2.25" of separation, or maybe it’s more. You set them that far apart, and then run your monster Rivarossi 2-6-6-6 Allegheny around the inside of the two curves where long passenger cars are parked on the outer of the two. I’ll bet you get an unwanted collision someplace. The point is that you would have been better off to have used perhaps 2.5" of separation, and you would only know that if you have conducted at least one trial with the very items at your disposal.
I’m not sure that the NMRA specs cover later developments or even outright errors on the part of the manufacturers. They are guidelines, good ones, but really everyone would be wise to test before ballasting or gluing stuck permanently.
1-1/2" ? Are you sure? NMRA S-8 sugests 1-13/16" as a minimum. Most prototype railroads consider 13’ to be minium. In HO 13’ = 1.793" = 1-25/32" +/- , only 1/32 less than the NMRA S-8. recommmendation.
1-1/2" would be 10’-10-1/2", pretty tight for equipment that is allowed to be 10’-8" wide.
Based on your photo that looks more like 2". Are you measuring center to center?
Personally 2" everywhere for all paralel trackage, straight curves, yards, mainlines. But I do have large curves to its not an issue there. Most paralel track commercial products are designed for 2’ centers. I use Atlas track which is also designed to give 2" centers for crossovers and yard leads.
Some old yard tracks were laid on 12 ‘0’ centers, and they are really tight to work around. I have a friend that almost got ‘cornered’ as a 89’ auto car kicked out on an old curved yard track in South Mpls one night. Sometime in the early 60’s the federal regulation specified 15’ 0" centers for new construction. Previous to that, many yard and mainline centers were in the 13’-14’ range. 2 actual inches in HO works out to something like 14’ 6". The Atlas Customline track system uses 2" as it’s default spacing for yard ladders/crossovers. I use 2" on tangent track and ‘widen’ it out to 2.5" on curves(just to be safe). A lot of folks use 2.5" in their yard tracks as it is easier to re-reail a car with a little ‘finger’ clearance.
Many prototype lines are now spacing mainline tracks wider to allow for m-o-w crews to remain ‘mounted’ while a road train passes at restricted speed. IIRC, the new UP construction uses at least 20’, and BNSF has been using something like 25’-30’ track centers on new construction or when adding a 2nd or 3rd mainline track. Considering the tight real estate we modelers work with, you made decide to keep thing s tight just to save space!
Jim, thanks for the information on current practices. It is interesting that the prototype is widening clearances.
I model the 50’s and as such sometimes forget things are changing now days.
I have always considered the 2" standard close enough to prototype for my era when 13’ was common and some tight trackage was 12’ as you mentioned. And yes, 2" is 14"-6" when scaled out.
My curves are 36" radius an bigger so I have never bothered to widen spacings on curves. I have no problems even with 85’ cars or articulated locos, but i don’t run many 85’ cars, most are limited to 72’ - 75’.
The Southern Pacific’s mid-twentieth-century standard for distance between double tracks and between main track and sidings was 14 feet, equal to 1.93 inches in HO scale. More distance was required when there was an object between the tracks such as a signal column where clearance of 8.5 feet from the closest edge of the object, making the distance between tracks something on the order of 19 feet.
This too is interesting, and thanks for the historical data. I model the east, the Mid Atlantic and Appalachia to be specific. Signals are more commonly on signal bridges, not between tracks, real estate more of a premium, and exsiting restrictions often made increasing clearances very expensive.
Fact remains, and is now well documented, 2" in HO is a realistic, reasonable, and convenient spacing.
Sheldon,That may look like 2" but,its 1 1/2" center to center.I should have place a “brakeman” standing between the cars.
On some of my short lived temporary yard(such as the pictured layout-a bad job) layouts I do not follow S8.
I use Atlas #4s with flex track and I add a slight inward turn curve.
When I was a student yard brakeman they taught me to lay down if I was between yard tracks and a string of cars starts to move.
Why?
The spacing is close and one could become dizzy and fall into the moving cars and another factor is you won’t be hit by a protruding load or metal strapping.
I got out a pair of Atlas HO scale flex track and set them 2 inches apart on center. In other words, if you lay two pieces of track next to each other, 2 inches on center would be the distance between the left rail of each piece of track (or the right rail of each piece of track).
Sometimes, modelers ask, “How much separation is there between the two tracks”, meaning how far is the left rail of the track on the right from the right rail of the track on the left. If the tracks are 2 inches on center in HO gauge, the distance between the left rail of the track on the right from the right rail of the track on the left is 1 5/16 inches.
For what it is worth, the distance between the two rails on a piece of track in HO gauge is 11/16 inch.
Must be an optical illusion there because based on the math, there would only be 1/8" or less between those cars, it looks like way more than 1/8".
Sheldon
Indeed…Those tracks looks farther apart then they actually were…
BTW…That nasty layout was built after I got out of the hospital after having my heart attack in '05…It lasted about 3 weeks before it was torn out.It was one big mistake built during a time of personal worries and deep depression.
I measured out two lengths of flex just this minute, ensuring an accurately measured 1.5" between track centerlines, and then placed two BLI H2a 70 ton coal hoppers on one of them. Viewed overhead, I didn’t bother to place hoppers on the track next to them because there wasn’t a hope…I was perhaps 3/8" too narrow.
It may be that some HO scale cars are quite a bit more narrow than others? Otherwise, it doesn’t seem possible to have functional track centers spaced less than 1.9".
