DMIR 29807 Coal Dump Car
I have a 6-29807 coal dump car. ( Built 2005 by Lionel )
The dump body will stick in the up position and wont go back down ( sometimes it will - but mostly it sicks in the up position ) I took it apart and cleaned the plunger-pin and the tube in the coil with isopropyl alcohol, and put her back together. She still does the same thing - sticks in the up position. Should the plunger be lubricated with some oil ? I don’t want to put any oil in some place where I should not.
I don’t think it’s the dump body, because I tested the operation before putting the dump body back on, and the plunger still was sticking in the up position. It will go back down with a slight push.
Any ideas ?
Steve
