Do I need a UP-5 @ Test Bench?
Hello All
I have a spare Digitrax DCS 200 and rather than let it collect dust on the shelf I thought I’d wire it up to my test track at the bench.
Question is… can I just keep a tethered DT 300 throttle plugged directly into the DCS-200 Or do I need to put the UP-5 in line on the Loconet cable?
Thanks, ED
you can plug your dt-300 directly into the DCS-200 with no problems. A UP-5 is only an extension of LocoNet. It is not necessary to have it. The only reason I would think you would need it is as a keep alive so that when you turn off the command station the throttle is not running off your battery.
Thanks…
Won’t need the keep alive since I’ll always have the dt300 plugged in. Just wondered if the up-5 needed to be in the Loconet circuit.
Thanks again!
It is a really good idea to have one at your work bench. In fact while you are at it go one better and install a DPDT switch there with both power and programming feeds to your test track on the bench. That way you can make CV changes, flip the switch and see/hear the results of the changes. This is especially great when it comes to adjusting the vaious relative sound levels, i.e.: engine, auxilliary, horn/whistle, and bell. John Colley, Port Townsend, WA
I have a six foot test track at my workbench that is connected to my Digitrax command station (DCS100). I have a PowerPax which is now obsolete as I have upgraded from a Digitrax MS100 to a PR3. I use my laptop at the workbench to program through Decoder Pro and also use Decoder Pro as a throttle for the test track. I had problems with a DPDT switch when I first set up the test tack. I exchanged the DPDT switch for a DPDT (center off) and it works great. I can program locos and then test run them. I can also test decoders and functions before installing the decoders.
