I need two lighting animations and although I have seen these, I lost track of the resource.
I am looking for a campfire animation, as well as an arc welding animation. The arc welder will be in a building and may only include the erratic light bursts which would be viewed by the lights changing in teh windows of the building. If I opt to make the scene visible, I’ll use Artistta figures, so I don’t need a whole scene, just the mechanism to create the lighting effect.
Likewise the campfire, I have all the figures, I just need something to put in the ground and build a pit around.
I have used Miller Engineering (Lightworks USA) material and it is excellent, but they don’t seem to have anything applicable.
Frank :I have seen those same ones you mentioned on E-bay & they may be in one of my favorite sites !! I think they were buy it now. I’ll start looking & get back to you !!
I ordered a fire sim circuit Model CFC1003 from Micro Magic Studios that I am well pleased with. I found it on EBay- search Model railroad - HO scale fire simulator. He just ended the free shipping sale and right now the item is not up- but I’m sure he’ll be posting again - you could email him. I tried to post a picture of my Hobo camp but I couldn’t get it to work - there are some pix on Ebay.
I use a circuit with two LM555 timer ICs for simulating a flame. A thin coat of red permanent marker is on the lamp.
For simulating a welding arc, I use an old transistor AM/FM radio with a tiny 1.5 volt lamp connected to the headphone output using a headphone jack. Adjust the volume/tuning/AM or FM to get a suitable flash rate. I put a thin film of permanent blue marker on the lamp. I also hooked up a LM555 timer to have about a seven second flash and three seonds of no flash. This circuit is in line with one of the wires to the lamp. I suspect you could also use the radio for a camp fire flame. Experiment.
If you have a dam, waterfall or brook, use a transistor radio under the layout and set the radio in between channels on the FM band. You get a nice hiss (white noise). Again, experiment.
I built my own white noise generator with two ICs, a few capacitors, resistors and speaker. It puts out a nice hiss.
