I was wondering if there are folks that still use, and prefer, lock-ons with their tubular tack?
With my temporary layouts I have used both lock-ons and direct connections by inserting spades into the slot on the bottom of the rails. I’ve never had a problem with voltages when using lock-ons. I find them to be quick, easy, and very effective.
I am at the point of creating blocks for my layout and decided that I will go with lock-ons for the permanent connections for each block (rather than use soldered connections or a spade into the slot in the center rail). To me they help enhance the classic “toy train” look.
I do. We set up floor layouts with tubular track and I find that a lighted lockon is a good idea when a CW-80 transformer is used. It helps create a load, which makes the e-units on some locos work better.
I use a combination. On each block, I have one lighted mth lock on as I like the look and I like to confirm that the power is on. I also soldier additional wires.
Ah - a tubular track thread to start the week - it’s all good.
I’ve abandonded the lock-ons in favor of soldering the connections directly to the rail. I’m trying to have everything blend in and they stand out too much for what I am doing.
On my previous temporary layout, lock ons were everywhere.
I’m using lockons right now but I intend to replace them with spade connectors once I find a cure for laziness. I bought a big package of them about a year ago (along with a bunch of wire) and I think they’re still sitting in the same place as they were when I brought them home.
I continue to use lock-ons for my temporary and Christmas layouts with no problems. I do tend to replace Marx lockons with Lionels. The Lionels seem to hold better.
I solder 14 AWG to the rail web and flange, on the side of the rail away from the viewer. A number of folks have said that they insert spade lugs into the rail. Does anyone use male fastons instead?
I use them as well, easy to install and also easy if you need to swap out a track section. If you have enough scenery trackside, they just seem to blend in after a while. You can always paint the lockon in earth-colored paints or to match your ballast.
Each remote switch has a built-in “lockon”(K-Line, 022, 711 types, maybe more) and I make my track power connections to the switches. Solves voltage drop problems across switches by using them as feeds.
5 terminals on K-Line’s(Common, Through, Out, Track, Fixed).
5 terminals on Lionel too… the 022/711 types can be used with a coaxial power plug instead of the Lionel “fixed plugs” - center(tip) is fixed switch power, outside(ring) is variable track power. Through, Common, Out are on the motor housing.
