Does this look as dumb? Rivision end of page 3
Or does it work.
Southern Pacific 1891
#4 Turnouts
Code 70 and 55
18" Min Radius
Is Carson City Yard as long as Sac Yd.? I think (thinking being a relative thing with me…) that you’re onto something…
Not quite, but long enough for 1891 trains–
Also the only reach that exceeds 30" is where the words Train City are, and that is all trees.
The only wall is the grey area in the upper right. The rest is walk around.
Chip, I think you’ve got a plan!
The only quibble I have (and, on a scale of 1 - 10 it’s about a -3) is the location of the tipple at the upper left. The mine is fine, but the loadout should be somewhere close to the center of the spur.
The usual way to do that would involve a long, spindly trestle from the headframe to the top of the loading bin - dead level, if possible. Side-dump ore cars would be rolled out over the bin and dumped. ‘Box on wheels’ mine cars would require a more elaborate unloading system. In your era, conveyor belts would not be used. Motive power for each car would be 0-5-0, two each, attached to a sturdy miner.
(Actually saw that in the late 1950s, at a, ‘Three men, two women and a dog,’ coal mine in Kyushu.)
I presume restaging will involve the Mighty Hand of God. Have you considered using sector plates to do away with some of the switches in Sacto and Carson City?
I like it, but I think Train City Yard is a “bridge too far”. Lose that and really consider making a sneaky out of sight connection between both big staging on top of your screen, you would have a wye capable of turning whole trains with no one the wiser.
Layouts that have staging on each side of the mainline really have potential to be very intense in operation.
You were rolling along just fine until you tried to make a yard in Train city, in my humble groveling, not so subtle opinion.
Actually, that is the one part of the layout already built. Just aborbing the previous layout.
Nice plan but you’re killing me. Southern Pacific from Sacramento to Carson City? No Donner Pass, no Roseville Yard, no Emigrant Gap, no Donner Lake, no Norden, no “Big Hole” no Truckee, no 2 percent grade, no Nevada County Narrow Gauge, wrong route…fine, just go ahead a jab a knife into this old SP Man’s heart. I feel dizzy…I think I’m gonna be sick…
The original plan had the tipple aobut 18" in when I dragged and dropped Rock Ridge in place I chopped that off and turned the rails. I can get about 6-9" with no problem. That will have to do, I think.
I have the head and the tipple built, but I was waiting for the final location to build the tressel. I have a couple of those 0-5-0 carts. One for ore, one for slag and dirt.
I think I get why Candell’s wye idea on the staging runs might be a good one[C):-)].
You seem to have provided the necessary run around tracks near the vicinity of the industrial siding that are facing point switches, so that is good. How practical shoving moves are with 1890s style steam pilots I cannot say. A full size cardboard mockup would be useful to help judge how much access there is to the wye and other central track. For a more modern layout I think the staging tracks would be on the short side.
Dave Nelson
They probably switched those one of two ways. Ran at the switch backed off a moment slack into the coupler, pin pulled and engineer stomps the hammer to get some space. While this is going on, the brakie on the car being cut off is throwing the brake wheel while another is tossing the switch between engine and car to be switched out.
A less dramatic switching would involve poling.
Or they probably simply went to far destination, turned around and switched those on the way back.
I saw the photgraphy and decided that what is built is built. My apologies for making a presumption that the train space was cleared and made ready.
As long as your trains won’t exceed about 2 ft in length (or at least the trains in one direction). So if you are planning more than about three or four 30-36 ft cars, an engine and a bobber cabose, you will have problem with the trains longer than they can clear.
It would work well. IT is so much better than what I can do.
Dave H.
I can actually get 5 cars plus a caboose and 2-6-0, but that is splitting hairs. I see my options as putting a curved turnout in a tunnel or running a siding along the river. Neither excite me. I’m open to suggestions. I do have a long passing siding in Train City.
Dave N.
The couplers on the front are Kadee #5’s–which are huge on an old-timer. But, if they don’t work I don’t have John’s dino.
Here are the changes I’ve made from your suggestions. Perhaps the biggest change is Crandall’s suggestion to make a wye out of the staging spurs. To do that I had to put a double slip in a tunnel–I figure that is about as dumb as I can get. I’ll have to figure a scenery option that will make it very accessible.
I also moved the freight station away from Sacramento Staging and put it on the spur with the Bear Wiz Beer brewery. Not may favorite option, but it was the only one I could think of. I can semi justify it as being near the passenger station. Again, I’m open to suggestions.
Here it is.
And here is a detail of the Train City Yard.
Chip,
I don’t see any major blunders, but that is some crawl getting from one side of the layout to the other…
I think you have one too many turntables for a layout of this size. I’d remove the one at Rock Ridge and its related locomotive service facilities. Rock Ridge is so close to the other turntable. I’d also enlarge the Rock Ridge mine to serve at least two of the tracks adjacent to it.
Regarding your icing platform…During your period California overland produce shipments were principally fruits: peaches, pears, table grapes, but after 1885 oranges and lemons were shipped east to displace foreign fruit.
Cars owned by the CP/SP/O&C and the UP designed for hauling fruit were mostly ventilated box cars. In 1895, the CP and its subsidiary O&C had 155 baggage fruit cars (thus I presume some produce was shipped on passenger trains), the CP and SP had 447 and the UP had 728 freight fruit cars, and the SP had 33 and the UP had 426 refrigerator cars. So, the majority of cars carrying California produce would be non-refrigerated. (I’m not suggesting you eliminate the icing platform. I just thought you’d find this information interesting and of possible use.)
Mark
Mark,
This is a walk around layout. The only place it touches a wall is the grey spot in the upper right. Once I build the layout and storage under it. I can expand around the walls. I’ve left space for it.
The mine is pretty much done and only has a single track tipple. I have a Climax A that will be a dedicated switcher for the mine and local community. The TT is there to turn the engine running the mine turn and local passenger train. Theoretically, the distance from Rock Ridge to Train City is farther than prudent to run tender first. A second reason for that are is that I plan to hand lay it in code 55. I have a deranged notion that I might get a merit badge for it.
I have a really cool icing platform, but I only really had it there because I though I needed it. I can save a lot of grief by eliminating it.
Anyone else have an opinion on this?
Mark,
Here is the layout in relation to the rest of the basement.
And here is the layout with buildings, street, river, and trees.
I’ve been thinking about the ice platform. When I expand the layout I am probably going to jump to 1909. Did the SP have working refers by then?
Re: Access to subterranean specialwork. Since you have a single site, right next to an aisleway, the quick and dirty solution is to make the terrain removeable. An alternative would be to mount the DSS on a removable domino, accessible through the fascia, which can be taken to the workbench for adjustment or repair. I would strongly suggest building it with Code 100 rail - bulletproof performance trumps prototype appearance when you can’t see the trackwork anyway.
Chuck (modeling Central Japan in September, 1964 - with LOTS of subterranean specialwork)
Good ideas. The DSS is under a tall mountain and I can make a side access hatch that will have about 12" of clearance. I have an excess of code 83 so everyting back of the tunnels towards staging will be code 83. That should be bullet proof enough (I hope.)
Chip,
The drawing showing how the layout will fit in the room makes my knees and back feel better.
Regarding refrigerator cars… As I mentioned earlier, the CP/SP had 33 refrigerator cars and the UP 426 in 1895…In the 1880s meat packers started having refrigerator cars built, particular Swift and Armour. Armour cars also carried produce…In 1902 the SP purchased 150 cars to supplement Armour cars which served the bulk of western produce business…Other railroads had refrigerator car in the latter 19th century, notably the NYC, Missourri Pacific, the Wabash, D&RGW, ATSF etc. Here are some car fleet numbers as of 1900: ventilated cars - SP 804, UP 758; refrigerated cars - SP 188, UP 404. …Both the SP and UP relied heavily on the Armour cars (I don’t know how many)… Then came Pacific Fruit Express (refrigerated car company jointly owned by SP and UP) in 1906 that changed the entire picture. By 1907, PFE had 6,600 refrigerator cars…All this info is from the Thompson/Church/Jones book Pacific Fruit Express by Signature Press*.* Buy it!
Mark
Let me offer you a strong lean on the wonderful Kadee 148’s They have saved me from 30+ years of chasing those copper spring peices forever.
