Double-cab electric locomotives
The Westinghouse built EP-3’s (AKA Quills) also had a heavy oil fired steam boiler which is described in a 1920 issue of “The Electric Journal”. The EP-4’s (passenger Joes) had the steam generator installed in the unused cab - info might be in Holley’s book on the Milwaukee.
The PRR DD1’s get the prize for most unusual steam generator as it was heated by electricity (600V traction power). The B.A.&P. electrics avoided steam generators by running 2400VDC to the passenger cars for electric heat - blower motors for forced air circulation used the heating strips as dropping resistors.
After the BA&P replaced the passenger trains with mixed trains composed of a long string of ore cars folowed by a combine, they installed stoves (IIRC coal) in the combine.
In the 1950s Westinghouse built for the PRR a couple of 2 unit rectifiers (E3b and E3c) each as a pair of streamline (single) cab units. They could also be seperated as single units.
https://commons.wikimedia.org/wiki/File:PRR_E3b.jpg
https://commons.wikimedia.org/wiki/File:PRR_E3c.jpg
GE also built for the PRR the E2b, a 2 unit set of AC electric streamlined (single) cab units.
https://www.classicstreamliners.com/lo-prr-e2b.html
A total of six E2b’s were built. They had AC motors and could operate in multiple with P5’s. The Westinghouse units (E2c and E3b) were early rectifier units.
But as I recall these didn’t last long … and didn’t we decide they were replaced with … nothing?
Some of the DD-1’s were replaced by various permutations of the L-5. Excess DD-1’s were transferred to LIRR. The remaining PRR DD-1’s and L-5’s were replaced by P-5’s when the New York Terminal Zone was converted to AC catenary.
I was referring to the electric boilers, not to the DD1s themselves.
It’s interesting that the DD1s were so successful for a variety of reasons that were not preserved in the L5s, which were some of the all-time dogs of electric engine design.
Then you have the O (by analogy to steam E), P5 (by analogy to K4) and R (basically enlarged P) approach to AC motors … not ‘all there’ for passenger work, although the two Os in multiple did a pretty good approximation of an eight-coupled steam locomotive.
All was redeemed by the GG1, so good that most of the postwar refinements in electric design were bypassed right to the '60s…
“Why is it that electric locomotives tend to be double-cabbed?.” The control power on the NHRR"s first electric, the EP-1 , was 14 volt battery-power , so a controller at each end was not at all difficult.The controller was designed with seperate “Fwd” / “Rev” levers ,the reverse lever romovable which made that contr oller in-operative.The control leads connected to electro-pneumatic valves. When the controller “selected” a valve , 80 psi pressure would force-close a contact connecting a motor-lead to the traction power.Four traction-power motors = 16 motor-leads connected to multiple contacts , both A.C. and D.C. For A.C. acelleration the motors were switched to succesively higher voltage values; for D.C. acelleration they were switched to succesively lower resistance values.
There is a great deal more involved in constructing two cabs on a locomotive than just the method of driving tap changing (which is actually how speed control on the modern New Haven AC locomotives was done, just as on the derivative GG1s). If you think about it, there are two full sets of brake gear, cab signals, lights, heaters, and other mechanical gear, even before you get into fabricating the cab structure with windows and collision bracing, and account for the diminution in usable length for packaging internal locomotive components or balancing weight distribution.
Connecting the motors to the transformer output power is a different function entirely, and it is only used at starting, and if for some reason it becomes necessary to isolate a motor (for failure). To my knowledge none of these locomotives have ‘transition’ as diesels do, but even if so this would be for series/parallel reconnection, which has little to do with actual command of the speed of the motor (either a DC voltage-controlled motor via full-wave rectification or one of the ‘universal’ motors running directly on the ‘tapped’ AC.
It was my impression that the accelerating resistances on the New Haven ‘universal’ motors running on DC were comparatively few, and as a result the actual balancing speeds were about the same as on the MU equipment – which is to say, not very many. AC MU equipment on PRR was not much better – I think you had only a couple of latching positions either side of ‘neutral’ and you used the brake for finer speed control if you needed to. (Watch someone who really knows how to drive older subway trains for the DC MU controller equivalent; e.g. how to make smooth starts!)
“Tap changing which is how speed control on ‘modern’ NH AC (electric) locomotives was done.”–The EP-1 prototype was operational in 1905 (I have the photo).There were only six “steps” , or “notches” for AC acelleration, far less than for D.C. For D.C. the traction-power motors could be connected to only one voltage-value, the 3rd rail voltage, which required for starting a two-motor series connection in series with resistors.For A. C. acelleration the motors were connected to six “taps” off the 11,000 volt transformer winding, each connection with a specific voltage-value.----“connecting the motors to the transfomer power is only used at starting.” Then what are the motors connected to for “running”?.
Nonsense. All AC electrics pass power through transformers under all conditions.
The word “taps” was missing. Transformer taps are only used on acceleration?
Probably also nonsense, unless the railroad had a rule:
“Once up-to-speed, full power or coast.” The IND New York subway had that rule at one time. Supposedly saved power.
Chicago Surface Lines conducted coasting experiments on a line through congested commercial areas where it was considered difficult to coast. The experiments did show reduced power consumption and coasting instructions were extended systemwide as a result.
I suspect this is a construction artifact being explained leaving fundamental electrical control out.
No practical railroad motor runs effectively on 11kV power directly, even larger ‘industrial’ ones adapted for jackshaft drive. (There were experiments to run DC motors in permanent series on 5000Vdc just before WWI, but the ‘big savings’ weren’t worth the fun).
Accordingly there is ‘something’ that steps the 11kV down to whatever the motors use for continuous running. That will likely be a transformer, and if it has no speed-regulation taps in its winding structure it would be connected and disconnected via contractors (probably with hefty blowout and arc chutes!!). The implication from the language is that the six stages of tap are on a separate ‘starting’ transformer that is sized for acceleration and then ‘switched out’ for the running one once the train has gathered momentum.
In my hymble opinion such a design would be transitory, perhaps even experimental, and perhaps limited by available materials or equipment. Certainly the EP-3 and GG1 used multiple-tap control on their main transformers – in part through the miracle of Pyranol.
Discussions of motor voltages can best be addressed by using the ultimate motor voltage / output voltages of hydro electric generators . Most generators are motored continously at speed so can immediately become generator as soon as water power is applied.
https://www.gepowerconversion.com/sites/gepc/files/product/Hydro%20Generator%20Brochure.pdf
https://en.wikipedia.org/wiki/Hydroelectricity
20,000 volts
https://www.brighthubengineering.com/power-plants/45558-electric-power-generators-how-they-work/
Interesting that at least some hydro generators are kept motored to reduce effective cold start times; I had thought it was only done for synchronization or to reduce shock if the supply piping had high head or other characteristic mitigating against stable acceleration in ~60-90sec. Keeping them spinning at some speed would also mitigate need for high-pressure prelubing of the step bearing during the early stage of spinup.
Interesting to see the professional take on this.
GE had investigated the use of 5000VDC for the Milwaukee, with the overall costs for the 3000VDC and 5000VDC being about the same. The savings in copper with 5000VDC were eaten up by the increased cost of the locomotives. It was also thought that the investment in copper was easier to salvage than the investment in locomotives.
There has been some work done in replacing standard iron core distribution transformers with switching power supplies acting as a transformer. High voltage side was 14.4kV and it would seem that such a beast could be adapted for 14kVAC or 20kVDC catenaries.
Am I remembering correctly that someone from Anaconda sat on the MILW Board, so choosing the more copper alternative may have been preferred?
You are remembering coorectly about the Milw board, but don’t think it had much to do with the 3kV vs 5kV decision. OTOH, Anaconda was interested in promoting electrification as a market for copper.
If I remember correctly, it’s a bit deeper than just board representation: some of the finance of the PCE came from people or entities specifically concerned with ‘maximizing the amount of copper’ in the construction. I have my suspicions that the fancy doubled trolley structure stems at least in part from some behind-the-curtain input into engineering.
It was my opinion years ago that 5000kV operation with twin motors (the armatures in series as in the Grass Valley experiment) would have been a sensible alternative – this was still the era of larger twin motors that didn’t handily fit between the backs of wheels at standard gauge, like the GG1 motors or the 428As that followed, but still a known and good alternative.
Is there a reason why Batchelder bipolar motors couldn’t run effectively on 2500kV apiece in series under load?
