I recently build a huge square train table with a hole in the center to walk around in only to find that it wouldn’t fit quite well without having to bend ore backwards to get around.
I want to take one corner of the layout and place it ontor of the other to male a double layer ‘L’ shaped layout. The bottom will be for a staging area and the top- the actual layout. Does anyone know how to do this?
I seem to be confused about what you are trying to do, but I understand that you want to cut some wood. I think a circular saw would be the best answer, but if it requires cutting some curves, I would use a saber-saw.
