Hi. I have two flywheels that I belive will work with a new motor if I can determine which type drive shafts will fit tight and snug inside the flywheel. I am familiar with the “hexon” designed for Athearn and plan to add this motor and flywheels to an Athearn locomotive (GP 38-2). Can you tell by looking at the photo attached? https://www.flickr.com/photos/jrpfilestoshare1/50006511987/in/dateposted-public/
I have worked a little bit with the Athearn flywheels. The Athearn BB shaft measure 3.15mm/.124” diameter and I have successfully shimmed them using a K&S 3mm brass tubing. I have removed the flywheels from the Athearn motors and reused them on can motors with 2mm shafts.
The 3mm OD tubing has a 2.1mm ID so I went with Super Glue Gel to help with the loose fit. Out of 6 conversions only one was out of balance.
The Mabuchi FK-280SA 14200 (14200 RPM) motors work very good as a direct replacement motor. Plenty of power.
If you don’t reuse the flywheels NWSL universals work very good in a Athearn BB.
