So the wonderous YouTube algorithm decided that, since I watch a lot of railroad videos, I’d like to view the “We brought an abandoned railroad” channel. Well, they weren’t wrong, its sort of interesting in its own way, if a bit off.
Anyway I suppose the railroad is called the East Terminal Railway, and several YouTube commenters (always reliable, of course) think the line in question is around here, east of Columbus Ohio. The new “owner” (possibly called Brian) describes what they plan to do in terms of the trackage (1. clear the brush, 2. fix drainage issues, 3. replaces ties and 4. re-ballast). Answers are not always forthcoming from them on YouTube, apparently they like instagram more but I don’t use IG.
The first video was amusing because Brian implies he is going to clear the row using a small electric chainsaw - in later videos you see a crew and bigger equipment in use of course.
Apparently Brian is associated with a railcar repair service called ReRail America, so there’s that (the stated plan is to start with rail-car storage). Don’t know how the two mix.
To store railcars, you need track space to store them - the owner of the track gets revenue from the car owners for storing the cars.
Sorry, I realize the last line of my OP was incorrect, I wanted to state that I guess they are branching out into a new business venture, from repairing rolling stock (and other railroad property) to now including storage. So, yes, the two can well mix, expecially as they stated they wanted to build an access road along the row (maybe they can fix and upgrade stored cars - why not?
If the location stated in the comments is correct, IMO there isn’t a lot of line to store railcars on anyway. They indicated the main client on the line was a can manufacturer, but but when you street view the building, by 2016 the dread “AVAILABLE” sign has been posted, and in 2019 it was listed as “the Spooky Place”, likely a seasonal Halloween Haunted walk-thru (or a fly-by-seaon wholesale outlet).
Rates vary, but a buck or two per car per day adds up.
A local shortline has had 700+ cars stored each summer. I’m sure it covers the payroll.
The North Shore Railroad was storing several hundred tank cars in the vicinity of White Deer, PA the last time I went up to Watkins Glen to race. Tracks that store cars only have to be maintained to the ‘Exempt’ level.
Calling P.T. Barnum? (he bought a railroad, but he isn’t a common carrier or applied to be one in recent history)
Larry, some questions which you may or may not be able to answer:
What kinds of cars are these? Are they owned by a few railroads/companies, or a lot? And why are they not needed in summer? And since this must take up about seven miles of track, how is it that the RR as that kind of space available? Are the cars on a branch line that no longer has any customers?
I was trying to think of what kind of car would be more likely to be used in seasons other than summer, and nothing comes to mind.
Many boatyards up here have this basic rule for winter storage: first in, last out. I’m guessing that a railroad storing cars would try to operate like that also!
The cars are LPG (1075), being stored during the summer - ie, low demand for heating fuel. These are all private cars (***X). The line in question lost its last customer at the north end of the line some time ago.
It’s actually about ten rail miles from Boonville to Lyon’s Falls. Of course, there have to be cuts for crossings, etc.
If I recall what I was told about the first year they did it, the short line didn’t specify LIFO, which posed some problems. Ever since they have specified as such.
A few years ago, the same short line stored some 1,300 hoppers on another unused section of track.
In another area they have stored cars that were being held for credit against new cars as opposed to being scrapped (with the metal being sent overseas).
Our new friends at East Terminal are back with a new video, which explains a bit more (and includes Brian (I think) griping about some of the brush cutting, which was kind of sub-par to be truthful).
To sum up:
As previously mentioned they are looking to store cars, including tank cars which Brian states is of a bit touchy subject as even if the tanks are purged and cleaned out passers-by and locals may freak out upon seeing them. Maybe they could hang big signs on the cars like they do on empty NY school buses to indicate there are no sleeping children left on board* - “This tank car has been checked for hazardous liquids”
Brian said they had to turn down a contract to unload a large transformer [I think] that would have come in via depressed center flat, due to persistant drainage issues at the proposed off-load site. Brian discuss how they will address the drainage situation, and that they plan to get a customer who unloads telephone/power poles.
Part of the area maybe used to offload steel construction mats (from flatbed trucks I’m afraid, but Brian said revenue is revenue, and he’s right).
Brian makes a lot of bad puns…
Will the East Terminal be the next Grafton & Upton? The next RJ Corman? The next…Iowa Pacific {shudder}. Who knows. Since they’re in Ohio, maybe one day JawTooth will show up to marvel at the reactivation. I’m sure YouTube will let us know…
*You will note the sign states “checked for sleeping children”, not that the driver or assistant did anything about them - “Yup, those kids are sleeping. Oh, well, let’s lock up and leave.”
East Columbus Terminal RR is exactly where?
He’s gonna have fun with FRA, STB and Ohio PUC - probably ending badly.
Unless the tank cars have been purged and cleaned, there will be an issue with storing them on anything less than FRA Class 1 track. With the ongoing fun in Louisville and the past stored tank car problem in Cincinnati, Mr. Williams (Bryan) might get himself in a little deep brown smelly stuff. (even private industry is not exempt from the FRA rules and the Excepted track qualifiers) … and this is different from the Hudson & Southern RR proposed start-up seen earlier on the forum in recent history (Akron RTA - Jeff White; that line used to run into NE Columbus) . Indiana Boxcar/Camp Chase related? Blacklick is CUOH (G&W, old PRR and B&O running side by side - the old PRR Panhandle is what survived?)
I have no idea if this man knows what he’s doing. You would think he’d have done the due diligence before buying that line. I’d love to know what he paid for it. To say it was overgrown is a giant understatement! I hope he does know what he’s facing, and I wish him well.
Also, nobody has asked how you go about buying an “abandoned” rail line. Legally, I would think that is impossible as real estate law in most cases states once the line is abandoned it reverts to the original property owner from whom the easement was obtained. Unless the line was purchased by the state and held in a rail bank…in which case it was not really abandoned.
I guess he could have bought it from the landowner, maybe just buying the track and some kind of buffer zone around it. I’m wondering what road this track used to connect with, if it still exists, and if not, then who has that line presently.
I guess a railroad would want the fees for hauling the storage cars to and from. Is there anything that would require a road to interchange with this new road? I wonder if Bryan plans to have a loco, or just let the connecting road go in and out for the cars. Brian does not mention any businesses on the line; it seems unlikely.
Well, maybe all the answers are on Instagram, but the few verified answers that East Terminal posted in the YouTube comments boil down to:
They have 2 trackmobiles they can use, I guess from their rerailer business.
They are in Ohio, but they don’t pinpoint exactly where. Locations are conjecture on YouTube.
Supposedly this track was owned by a company (“beer can plant”) which closed down, althought other businesses still exist.
Usage will be car storage, and apparently some trans-load operations as i mentioned before.
And that’s that.
Not exactly the High Iron. But good to see tracks come back to life.
The weirdness continues near (south of) Byesville, OH with a piece of former B&O/CSX/CUOH track that shows the confusion that can happen when people don’t play by long established federal rule. Don’t think this is the subject of this thread, but just as weird. (and “I dunno” won’t be accepted as an excuse) … STB FD-36432/ Independence Rail Works / 3.6 miles of Guernsey County OH track
Most recent video they posted was about a ‘road trip’ to a Ritchie Brothers auction site in search of ‘deals’ on unspecified equipment.
Given what they’ve done in the past, they would be smart to go looking for a 988 or a 980B plus a 4WD backhoe. Rare that you find on-track equipment with Richie Bros…even stuff with high-rail gear would be unusual, more the domain of Sterling, Danella et al…
i saw the ‘Field Trip to Richie’ video yesterday as well, Brian and son seem to be having a blast goofing around on YouTube and showing off stuff like their new ‘Rail-Saw’. The permission slip bit was kinda cringy…
mudchicken, not sure they need any big Cats at this time (although having a back-hoe never hurts); I am pretty positive they are not deep in the thickest forest of Ohio, but rather on the outskirts of an industrial park on the east of Columbus Ohio, next to suburban subdivisions.
We know they are in Ohio, and they kinda let slip they are sorta around Columbus.
Brian in a response to a comment in an early video about the line stated the main plant which used rail serve was a (beer) can manufacturing plant that had closed some years back. Turns out Ball Corporation had closed their manufacturing plant at 350 McCormick Blvd in 2013 (the building with 3 tracks approaching it - more or less the same map link I posted in my OP, and suggested by other commenters on YouTube). As a additional clue, they kept talking about having to direct their drainage to flow north to a retention pond - well, north of that plant is indeed a retention pond (the bigger, square one, the smaller rounder one is likely part of the housing developement)
Going by Google Maps (not necessary the best idea), as you can see by the map link above the line they have goes North and then curves East - likely to the switch off to Amcor Ridigi Plastics (which seems like it still exist and is an active rail user, but you can’t really tell from undated Google aerials) - well, in that case the distance East Terminal runs is less than a km. Even if Amcor Rigid AND Cemex gave up on rail (sadly, not infesible) and East Terminal went all the way to…Ohio Central? CSX (the OC map on their website…stinks), its still only ~1.02 miles (1.64 km). Oh well, the paved area in back of the former Ball Corp. plant would make a good p
Their Ritchie Brothers footage highlighted several RJ Corman units that were being sold - one with rail wheels, the others without. Considering how Ritchie Brothers have various auction sites around the country I suspect that it is a relatively easy way for owners of specialized equipment to get it sold into the secondary market.
