I’m hoping maybe you can help, I have a proto 2000 gp7 (Blue Box) that I am installing a econami eco-100. all seems to work ok, however I’m not clear on wiring this keep alive that came with it, its just a capacitor there are no wires on it. the directions say to solder the green/Yellow stripe wire to one end and the blue common to the other, that did not work. The decoder seems fine thank god. all the websites mention wires on the keep alive but mine came with none, is there a polarity thing on those? I see a plus and minus on the instructions but the capacitor has no markings.
Any help you may have would be appreciated. thank you!
The blue (common) wire is positive (+) so that one should go on the “+” leg of the capacitor and the green/yellow stripe on the negative (-) leg. If the capacitor is not marked on the barrel, the “+” leg will be the longer of the two legs.
Rather than using the supplied capacitor, you could opt to buy the Soundtraxx Current Keeper that will provide a reasonable amount of “stay alive” functionality.
