Is it possible to edit one of your own topics once it has been posted? I see that I left one word out of my previous post.
Yes; look at the mystery-meat icons in gray at the bottom of each of your posts. The little pencil reopens the editing window at the bottom… NOT the text you will still be able to see at the top. Make the changes and use the same button that was called ‘reply’ – it will now be ‘save edit’.
NOTE that if you are on an iPhone you will have to close the ridiculous bottom ad window to get to that ‘save edit’ button…
Thank you. It has been done.
