Electrification of the Northeast Corridor, NYC to Boston
Yes…very strong…I would imagine down at the bottom of Hoover Dam B***** the water is pushing on it roughly 350lbs./ sq. in…{When it’s filled to capacity}.
“Amtrak has four grade crossings left on the NEC between New Haven, CT and Providence, RI that I know about. From the south to the north the grade crossings are located in New London, CT (2 grade crossings), West Mystic, CT and Mystic, CT. The grade crossing in Mystic, CT is located at the Broadway Avenue Extension on a curve just west of the Mystic station. It is protected by four quadrant crossing gates so the trains do not sound their horns for that grade crossing”
Actually a lot more than that.
From North to South:
Westerly - Palmer Street - 100 MPH
Mystic - Elihue Island Road (AKA Freeman Road) - 70 MPH
Mystic - Walker Road - 70 MPH
Mystic - Wamphassuck Road - 80 MPH
Mystic - Latimer Point Road - 85 MPH
Mystic - Broadway Ave Ext - 70 MPH
Mystic - Shook Street - 85 MPH
New London - Governor Winthrop Boul - 50 MPH
New London - State Street - 35 MPH
New London - Bank Street - 55 MPH
New London - Miners Lane (AKA East Neck Road) - 80 MPH
Note that all crossings are well below the 110 MPH maximum allowed by the FRA. Also some of these do not have four quadrant gates as mentioned previously.
Behind that fancy fiberglass front is is a front coupler, air lines, MU cables, and a metal “crash cage”. The slots down low on each side of the nose hides the release handels to lift the shroud so an Acela can be towed by a rescue diesel if needed. The Engineer sits high up on a control platform. His seat swivels to the left allowing him to drop down into a protected area behind his seat in event of a collision. Bullet Trains have been developed for 50 years around the world, designs keep getting better. The Acela is designed to protect the Passengers and Crew, but, anything it hits ??? that’s another story.
Remember, that Headlight rounding a curve a mile away will blow by you in 24 Seconds.
Actually, most engines are pretty strong when compared to any vehicle they may hit.
The orange metal you see wrapped around the front of this NC DOT F59 used to be a tractor trailer loaded with bricks.
