EMD 4 Stroke Cycle Engine
Appears to be a revision of the 265H. No surprise there…
Are you describing the picture of a V12 on page 16 of the Dec 2014 Trains magazine?
Jim
YUP
Appears to be fitted to one of the ex-SD90/SD89 demos that was gutted earlier.
In their December issue, “Trains” magazine illustrate a twelve cylinder engine clearly mounted in an EMD locomotive, possibly an SD 89MAC or SD90 MAC, described as a test version of EMD’s proposed Tier 4 locomotive engine.
It is clearly based on the EMD 12-265H engine, but has a number of obvious differences from the relatively few published photographs of 265H engines. The most obvious difference is seen in the inlet air ducting. While the 265H used flat ducts that apparently served as intercoolers, the new engine has cylindrical inlet ducts from what appear to be conventional box like air to water intercoolers. This type of duct is used on the C175 and the GE FDL.
The turbochargers have been moved from above the alternator to the free end of the engine. Not being familiar with the free end of the 265H, I can’t say if the new engine is different in that area, but the area below the twin turbochargers looks fairly complex, although there are obvious ducts from the turbochargers to a point close to the engine inlet air ducts. I expect that exhaust gas recirculation takes place around that location.
The cylinder heads are different, with an angled extension that may contain electronic fuel injection control equipment. The connecting air inlet ducts to the individual cylinders are quite similar to those on the 265H and it is these that suggest most strongly that the 265H was the basis for the new engine, and not another Caterpillar four stroke design (although the C175 has cross flow heads). It is obvious that the new engine retains the cross flow head design used by the 265H which was in turn probably inspired by the GE FDL engine.
The exhaust beyond the turbocharger looks as though a diesel particulate filter may be incorporated in the muffler arrangement.
We can also count on M636C for some good insight in these types of subjects [:)]
Additional thoughts-
The 265 H was designed with jerk pumps and nozzles-which are concealed under the rocker covers. Control was via EMDEC. I wonder if the new engine will be equipped with common rail fuel injection. The photo gives no clue.
On the H, the segmented camshaft is located high in the middle of the vee-which complicates access compared to the 710.
At the onset of 265H production, the cast block was supplied by CAT. With that said…
It appears that Ainsworth and company made a rather large blunder in delaying development efforts towards a Tier IV engine. Appears that CAT has asserted their control of EMD…and the ainsworth crew may getr kicked to the curb. There is little experience in their collective background that equips them to manage EMD. It is a mystery to me why CAT was not aware of that fact.
If EMD had been prepared for Tier IV and had managed to obtain say, 20 % of the one thousand GE Tier IV locos on order, I would guess that the revenue might have been in the neighborhood of 600 million dollars-exclusive of renewal parts support, customer training and other services.
The PR obsession with cost cutting-and ignoring the possibilities for growth-has come to bite them on the you-know-what.
CPM500
The article does mention that despite saying they won’t have a locomotive until 2017 they’re actively trying to beat that date. So who knows really…
Will their emission credits allow them to build any US locomotives next year? I’m assuming no, since this month’s issue makes it sound like GE will have to produce at least one domestic Tier IV locomotive next year for every emission credit Tier 3 example produced for US customers next year.
Will that still be able to be applied by EMD (They’ve also built up some emission credits) when they do have a Tier IV solution, allowing possibly a few more SD70ACe orders the year when its successor enters production?
There are no Emissions Credits covering EPA Emissions Standards. However EMD can continue to build locomotives like the GP20C-ECO. CP is said to be very satisfied with the GP20C-ECOs and after further testing the SD30C-ECO locomotives. There are only 10 more options on the GP20C-ECO, but there are potentially several hundred SD30C-ECO candidates.
They’re referred to in the article as “Tier 4 Credit Users” and it’s stated that for every “Tier 4 Credit User” locomotive built (Tier 3 emissions standards) in a calendar year a Tier 4 locomotive must be built. The article doesn’t state if it has to be in the same year…
It is a long time since I’ve seen any details of the 265H but unit injectors seemed correct.
I’m advised that the only way of meeting Tier 4 NOx emission standards is to use common rail injection. The technique is to use multiple small injections per stroke which keeps the peak temperature low enough to avoid NOx formation. This also reduces the peak stresses in the cylinder while maintaining a mean effective pressure.
The illustration in Trains shows an angled rectangular projection from the cylinder head cover which might enclose electronic injection control and might indicate the location of the common rail feed.
The reference to Tier 4 Credit reads “for every Tier 4 Credit User locomotive built in a calendar year a locomotive to Tier 4 standards must also be constructed”. I read that as meaning the matching Tier 4 unit must be constructed in the same calendar year.
M636C
That’s what I was thinking, for how long are the credits valid and could EMD build Tier 3 in 2016-2017? That’s probably the more interesting question.
Text of Title 40 Part 1033: Control of Emissions from Locomotives
http://www.ecfr.gov/cgi-bin/text-idx?SID=914e5125a27c447773834b4203f48082&node=pt40.33.1033&rgn=div5
I wouldn’t take anything presented b y EMD ]within the pages of TRAINS as gospel. CAT/PR/EMD has made few official statements on the business in the manner prescribed by corporate governance rules. By comparison…
If you look at GE’s official statements or press releases, there is always some boilerplate at the end-something to the effect that “This is a forward looking statement…” and so on. In a word…a disclaimer.
Could someone cover the basics of the operating history of the 265H? All I ever heard is that there were engine problems in use with the SD90MAC, and that they were a reason for their limited use. Can someone say what was failing and why? Then there is the question of what would be changed in an improved version to eliminate them.
I seem to remember at the time of Caterpillar’s purchase of EMD there were features on EMD’s skill with 2-strokes and their confidence in meeting future fuel and emission standards. Guess that wasn’t so. I also note they don’t seem to be trying to shove a cat 3612 into an SD. Guess they can’t fix the old broken crank issue.
The CAT 3612 has been replaced in the catalog by the C280 series engine which is an evolved 3600 (think GE HDL to GEVO). There is a Tier IV compliant version but, like the C175 that Cat/Progress/EMD is going to use in their new commuter locomotives, the system uses SCR(i.e urea) which the railroad industry is saying it does not want in locomotive applications.
The 265H was part of EMD’s previous research into Exhaust Gas Recirculation technology so it is the logical starting point for a 710 replacement (whether or not the railroads will be happy with it remains to be seen).
We had at least one fairly detailed thread on the problems back around 2002-2003, but I’m not able to look up the specific reference from here.
The principal issue I remember with the 265H was cavitation, due to ultrasonic vibrations induced at some points in the crankcase at high power levels. Something very similar was reported for the modified Deutz engine design GE was using. I don’t have access to the specific information – but I suspect Will Davis and Peter (M636C) know where to find and display it.
I’m afraid that the 265H and HDL are a bit of a mystery to me…
There was a contemporary issue of “Rail News” magazine at the time of the introduction of the 6000 HP engines that gave more details than I’ve seen elsewhere. Sadly, I couldn’t find my copy when I last looked. This was before the difficulties emerged, of course. One thing I recall was that the “Rail News” article suggested that the EMD engine was enlarged in bore and stroke to match the power output of the GE/Deutz competitor and that the earlier EMD version was known as the 854 (if I recall correctly) on a cubic inch displacement basis, and that engine was expected to deliver 5000 HP from a V-16. If all that was true, and the enlargement occured late in the process, developmental difficulties could well be expected with the enlarged engine.
On the other hand, I recall seeing references to the GE HDL indicating that GE were unhappy with the structure of the crankcase as des
[quote user=“M636C”]
Overmod
LensCapOn
  1. Bore and stroke of the ‘GM 16-265H’ (as the engine is refered to within EMD Technical pubs.) is 265 mm by 300 mm, making the engine ‘undersquare.’
  2. Displacement is 16551 cc/1010 cu. in per cylinder. I don’t know how the ‘854’ descriptor evolved.
  3. The power assembly can be removed as a unit.
  4. The upper flange on the liner flows jacket water into the cylinder head and out of the engine. Most of the length of the liner is not cooled by water…only the area where combustion takes place. Hence the block can be considered to be ‘dry.’
  5. Exhaust gas recirculation was not present in the 265 H.
  6. EMD management felt that the 710 had been developed to the point where it could not meet future performance criteria, e.g., hp/cylinder, emissions…and son on. Hence, the 265 H was developed.
  7. Two stroke cycle engines (either gas or diesel )present some unique challenges in controlling emissions. I note they have all but vanished from most new land transport vehicles.
  8. The 265H engine was developed at a time when GM’s share of the automobile business declined precipitously. Accordingly, funds for EMD to engage in future product development were limited at the time the engine was developed.
  9. The '14th floor at GM (senior management) was not engaged with respect to EMD.
  10. A cast block is the norm in medium size, medium speed diesel engines.
  11. The application of a fabricated structure for a locomotive engine block came to GM from an outside firm that was a pioneer in replacing cast structures with fabricated substitutes. Note that Alco aped the fabricated block with the 244 and later 251 engines, as did FM with the OP.
  12. FWIW, Indian Railways engaged a Chinese firm to supply cast 251 engine blocks for the high output 16-251 engines.
  13. In the modern world, the quality of large castings such as diesel engine blocks is far more consistent t
I’d love to find some good technical data on the 265 engine or “H-engine”. I’m a diesel mechanic and recently became a locomotive machinist. From what little I’ve been ale to gather the “H-engine” is very similar to GE engines. Do you know of any good sources of information?
