Engine Runs Better in Reverse Than Forward
Taking my HO locomotives out of the mothballs for the upcoming holiday season.
What might it suggest if an engine runs better in reverse than forward? In this case, it not only goes faster in reverse, but also more smoothly. Running forward, it goes slower and sputters.
It was cleaned and lubed. Also, it is a steam engine, so I don’t know if the side rods are a factor.
Any ideas?
I have a BLI Hudson that behaved like that for a while. It was a slippage in the drive train. A drop of CA fixed it.
Thanks. Pardon my ignorance, but what is CA, other than California?
Classic model railroad truth - steam locomotives shall run better in reverse than they do in forward. It is and always has been this way.
CA is cyanoacrylate adhesive - “super glue”
So true! I thought that kitbashing my Rivarossi AC-9s from Cab Forwards that the AC-9s would run better forward than reverse because they are Cab Forwards running in reverse but not so. The Kitbashed AC-9s run better in reverse than forward, go figure.
Steam locomotives must like pushing the tenders better than towing them.[;)]
Mel
My Model Railroad
Bakersfield, California
I seem to recall a similar question not that long ago…and found it HERE. Perhaps some of those responses will be helpful.
I have some Athearn BB locos that act the same.
Mike.
If it’s a Bachmann 4 4 0 with motor in the tender, it’s because the worm gear thrusts against a much larger around surface running forward, and a very small thrust surface, thus less resistance in reverse. Dan
So, why don’t manufacturers put the light in the rear of the engine, and not tell the engine that they are doing this? That way, the consumer can flip the body the other way. Will the engine know it is running in reverse with the body facing the wrong way?
Kind of like the way Richard Brautigan would sneakily type only a few words at a time on the typewriter, so his new novel wouldn’t discover that he was writing it.
