Hey guys, I decided to reset my ESU decoder using CV=8 and now my loco has no sound, no lights and not moving at all.
The loco is brand new and was working fine when I got it but for some reason the day after it was working fine it started running very erratic so I thought a reset back to factory defaults might fix it.
It didn’t and now the loco has absolutely no functionality.
The decoder CV’s can be read using my NCE PowerCab, so it seems the decoder is alive but just not playing ball.
Did you cycle the power? This is needed to complete the reset. Maybe do that two or three times, waiting a few minutes between power cycles. It should take about 5 seconds for the reset process to complete.
It is also recommended that service mode be used, not Ops Mode, for a reset.
An ESU decoder can have any valid address as its default. The decoders are supplied blank to the retailer and are loaded with the desired sound project at the time of sale. A number of defaults can be set at that time, including the address.
Can you describe the erratic behavior? There are known issues with the LokSound 5 where cheap components were used and caused either partial failures or complete failures/melt downs. I had 3 locos of the same run either fail within the first few hours or after several days (20+ hours) of run time.
If this loco is brand new, I would return it for replacement or repairs.
According to the ESU Loksound 5 instruction manual, the default value for CV1 is 3. I don’t believe I’ve ever bought a blank ESU decoder, or an engine factory-equipped with and ESU decoder, that didn’t use 3 as the default address.
You are missing the point: ESU decoders can have any valid address set as the default. The LokProgrammer can set a number of defaults, including the address. When a reset is completed the address will be whatever was set as the default. Many times it will be “3”, but it does not have to be that value.
