I’m thinking about modeling an ethanol plant on my eventual layout. I was looking at the local plant for inspiration and think it can be compressed easily enough. I do have a question on where the ethanol is loaded onto tank cars. I took two screenshots of the aerial view.Is the big long pipe stretching from the white tanks to the tracks the ethanol loading spot, or is that where gasoline is offloaded? Is it both? Thanks in advance.
I don’t know about you’re question, sorry. But… I picked up a copy of the walthers catalog, and they had a special article about their new ethanol plant series structures. They also had a layout and described how the plant would be switched with a tail track, one track for empties, one for loaded, and cycling the cars through the loading/unloading sheds.
I thought it was so cool, that I modified my new layout for this ethanol plant series!!
The gasoline probably comes in by truck.
That is where they load the tanks.
Gas comes in by truck at this plant.
WSOR 3801, you would have more pictures of the plant (not that I mind). Thank you very much for the response, and to everyone else who replied too.
If you get a picture that goes a bit more to the right, you would probably be able to see the gasoline truck offloading area and gasoline storage tanks. You can see a pipeline heading to the right of the ethanol storage tanks.
What would interesting is to know the process for blending since there are 2 large and 3 smaller tanks in the photo.
Ricky
I think they use the gasoline to fowl the ethanol to avoid paying alcohol beverage taxes. They add 5% gasoline to denature the ethanol making it unfit for drinking.
I actually just found an ethanol plant just northwest of Denver in Windsor, CO. Which fits my prototype perfectly with my new layout.
My guess is that they inject the gasoline into the ethanol stream as it goes from the tanks to the loading racks.
