(example)Old ZW xfmr to power newer electronic locos. What amp fuse to track ?
You don’t put a fuse between the transformer and track because guessing what value of fuse to use would be pure guesswork. Too low a value and they would continually blow; too high and they would not protect your power pack or locomotive. Also, what do you mean by “old” transformer. Some may be too old for use with newer locomotives.
A type 1156 automotive taillight bulb is usually recommended to absorb excess current from short circuits.
Welcome, Tallow Pot. Your message text is not appearing in your message. Your thread title for this thread appears, but you are not apparently typing a message in the text box. Please type your reply in the large blank box that opens between “Message” and the task bar with all the tiny icons, and the thin box with “Tags” just above it. The large box is where you type your message, and then click on “Post” at the bottom of all the boxes that appear.
-Crandell
