I just watched a you tube video that claimed the F in F3,etc. really stands for 1400 hp. I have never heard that before. Can anyone confirm that or was the announcer speculating?
From what I understand. The F3 stood for Freight locomotive 3rd model. The F7 would be freight locomotive 7th model in the series. Why EMD put E in the front of their passenger locomotives is beyond me? Just like Caterpillar calling their first commercial tracked tractor a D2. Some people think it’s because of the diesel engine. According to the official Caterpillar statement. It sounds good. That’s why. The original D2 was designed to run on kerosene. Diesel fuel was not found everywhere but kerosene could be bought anywhere, even drug stores.
Pete.
Yes, on the ORIGINAL FT locomotive, the F stood for 1,400 horsepower. I believe a cab unit with one booster actually was rated at 1,350 horsepower.
With the ORIGINAL EA passenger service diesel, the E stood for 800 horsepower.
Interestingly, the original switchers were the SC-1, SW-1, and NW-2. The “S” stood for 600 horsepower, and the “N” for 900 horsepower. The “C” and “W” stood for cast and welded respectively for the type of frame fabrication. I do not know if there was ever a model NC-2.
Later… as rational thinking took over… “F” became synonymous with freight cab units, “SW” became used for all switchers, and for some reason passenger locomotives continued to be “E” units.
The locomotive model letters ceased to have anything to do with horsepower by the time F-3s, BL-2s, GP-7s, SW-1200s, and E-3s showed up. I do not think “GP” or “BL” ever had anything to do with horsepower.
Wow, look at that, I answered a question in the Prototype forum… I hope I was accurate.
-Kevin
The BL stood for Branch Line. GP stood for general purpose. And SD stood for Special Duty.
Mike
I think you might have meant 1800 hp (two 900 hp engines)
Yes.
I will leave the Prototype Information answers to better informers.
For what it is worth… Were there any real differences between the EAs, E1s, and E2s? I have been told they were all the same locomotive, the only difference being which railroad was the original owner.
-Kevin
Kalmbach has two excellent books on E and F units, available on their websites. You are correct about the E units as some there road specific modifications, as the CBQ’s stainless steel and the SAL pneumatic nose doors in order to access other units.
Ed Burns
There were minor differences in the internals, but the big difference is that the car bodies were all different. The B&O EA and the ATSF E1 had similar car bodies, but not completely the same.
The UP E2 was unique.
Sheldon
All B&O EA/EBs were built with Westinghouse electrical equipment. All Santa Fe E1A/E1Bs were built with GE electrical equipment. The Union Pacific E2s had one set built with Westinghouse equipment and the other set built with GE equipment. EMC settled the issue by creating near copies of the GE electrical equipment with the E3s. Data from EMD Product Data.
Ed in Kentucky
No, each FT unit was 1350 hp
“Two NC2 locomotives were built in July 1937 for the Missouri Pacific Railroad. They were functionally identical to the NC1; Pinkepank states EMC as recording, enigmatically, “Wiring” as the difference. They were EMC S/N 714 and 715, MP #4100 and 4101.”
EMC Winton-engined switchers - Wikipedia
I have heard a story that “wiring” meant that they were MU equipped (rare on switchers in those fragrant days of FDR’s Second Administration). But pictures look like this was not the case. I have also heard they were equipped experimentally with aluminum rather than copper wiring to see the difference in manufacturing cost. I can vouch for neither of these stories.
The NW2 had a 1000 hp Model 567 engine, replacing the 900 hp Winton Model 201 on earlier units, but retained the “N” designator
E unit originally stood for 1800 hp (two 900 hp 201’s) and the letter was retained for the E6 (2000 hp - two 1000 hp 567’s) and later passenger units. Everybody in railroading knew what E stood for, so why change?
FT, the short answer is “no one knows” - although F was a rounding up of 1350 hp per
Actually, the SW1200 was a 1200 hp unit and its little brothers, the SW900 had 900 hp and the SW600 had 600 hp. The SW1000/1001 were 1000 hp units and the SW1500 and various MP15 models were 1500 hp, as were the GP15’s. EMD made a stab at it with its 1959 generation - 1800 hp GP18’s and SD18’s, 2000 hp GP20’s and 2400 hp SD24’s. EMD then abandoned that approach with the GP30 for marketing reasons - it would have been the GP23 (2250 hp) competing with the U25B (2500 hp). There was even an obscure light roadswitcher called the RS1325. Oh, yeah, the SW8 was 800 hp - but its contemporaries, the SW7 and SW9, were NOT 700 hp and 900 hp.
You want consistency from “Every Model Different”?
I don’t have my copy of the Classic Trains F-unit issue available at the moment, but as I recall it did explain what the letters actually meant. And EMD also referred to some units as “FS”, not “FT”.
Interesting that they didn’t continue to use the model TA designation for a four axle unit with a single 16 cylinder engine.
I believe this stood for 3 unit consists with the FTSB (FT Short Booster) sandwiched between two FT A units. Remember, that EMD viewed themselves as selling complete locomotives, not units that could be assembled into a locomotive by the railroad.
“The B-units of FTs ordered in semi-permanently coupled A-B sets, and those with couplers on both ends, have a large overhang on one end (the coupler-equipped end on the paired units) featured on no other EMD B-units. This is not present on the B-units in semi-permanently coupled A-B-A sets, which were called FTSB units (for Short Booster).”
As noted, the original FT design was for two 1350 HP units connected with a drawbar, one A and one B, but treated like one locomotive - kinda like how a Mallet is just one locomotive. In the original design, there was no way to connect the A and B with a coupler, so you could only run them as A-B sets, or back to back in A-B/B-A sets. This produced either 2700 HP or 5400 HP.
Unfortunately, most railroads needed around 4000 HP for a mainline freight, so one A-B set wasn’t enough and two were overkill. The FTSB allowed two A units to connect together with the FTSB in the middle, producing a 4050 HP lash-up. Some railroads after WW2 chose instead to buy F2 and/or F3 A units, and mate them to the FT A-B sets to produce 3-unit sets. (BTW unlike FT B units, the FTSB had no room for a steam generator and water for passenger service.)
One story for the FT name is it stood for FourTeen hundred.
The FS designation was for a unit built with couplers instead of drawbars between the units. All Santa Fe FT units were actually FS units. Some 37% of all FTs were actually FS units. The FS type was originally owned by Santa Fe, Rio Grande, Southern, Missouri Pacific and Cotton Belt.
Read this FT article by Wally Abbey: EMC’s FT Locomotive (utahrails.net)
Ed in Kentucky
Thanks for that information. This clears up and answers a lot of confusion I had about the FS designation.
-Kevin
Part of this was on the railroad unions. With steam, each locomotive required a crew, so if you stuck four diesel locomotives on the train, they expected (demanded) four crews to be called, not one. Drawbars and cabless B-units were initial solutions to a problem that had to be ironed out. And “ironed” because some locomotives lacked MU connections, some locomotives - usually from different manufacturers - couldn’t MU with each other, and because the diesel came at a time when traffic was ramping down post-WWII just as employees were returning from military service, unions were willing to fight hard to get compensation as the writing was on the wall for fewer needed employees in the diesel era.
The air brake had reduced the numbers of brakemen needed. The doodlebug the size of passenger train crews. The diesel the number of crews in general. State and federal laws reduced the size of a “full crew” from 5 or 6 down to 3, and eventually two or even one in the post-caboose era. And nowadays (in the computer era) there are automated trains without any crew at all. Progress! … NOT!
I have a stack of Classic Trains in the …reading…room. One is the E-units issue, I have read it many many times. Explains all the E-units.
Seems like an odd way to designate horsepower especially given it could just as easily stand for 1500. On the other hand, it’s no more strange than the UP designating their Northerns as FEF which stood for Four-Eight-Four. I brought this up about ten years ago and we had a lot of fun comming up with acronyms for other wheel arrangements such as the 2-8-8-2.
It’s interesting (to me anyway) that for the first 20 years or so of diesels, horsepower seemed to be a key identifier. Trains magazine in the 1950s might label a picture of a train pulled by 3 GP-7s as having “three 1500 HP GM diesels”.
