Fast Tracks Turnouts
I’ve seen several threads asking if the Fast Track Turnout Jigs are worth the money. I guess they would be if you were doing more than 15 of the same type, however, I’m not and can’t justify spending $190. for a couple of turnouts.
I needed two large radius curved turnouts for my layout. I’ve seen curved turnouts by Shinohara at the last train show in my area for $28. Quite a cost for a curved turnout. So I checked out Ebay. I found someone making Fast Tracks curved (32" outside and 25" inside radius) turnouts for $32.50. Since these turnouts have such a great review I bit the bullet and bought two.
They were shipped on Saturday and arrived yesterday, only one day shipping (very good!). I checked them out last night and the guy that built them did a fantastic job on them. He also asked me if I wanted them drilled and where to drill the hole in the throwbar.
These are by far the smoothest working turnouts I have. If I need any more special made turnouts I’ll be looking for this same person to build them for me.
For those who want just a couple of fast tracks turnouts and don’t want the expense of purchasing the kit I suggest looking on Ebay. There are several people selling them at different prices.
I’ve heard everyone saying how much better these turnouts are compared to store bought and I have to agree. They are truly superior to any store bought turnout.
Bill
Yup.
Keep in mind that you can use the frog/point tool for turnouts other than the ones you buy the jigs for. In fact, there are alot of people who spend the 50 bucks for the point/frog tool and just handlay the rest by printing out Fasttrack’s templates and using them as a guide.
For example, if you buy the #6 frog/point tool, you can then make, left, right, curved, wye, 3way and slip turnouts by printing out the template.
I look at the jig as a stepping stone to handlaying.
David B
I would go like Joe Fugate, use the Central Valley ties as template.
I did this too in a similar way with my Diamond Valley module: Turnouts.
Now I would use Central Valley tie web with PROTO87 frogs and throw bars. That’s my experience!
Wolfgang
[#ditto] And for about 1/2 the price…
Of course, by doing this, you’re counting on the skill of the builder/seller to be high enough to produce the quality you want.
I do indeed find using Central Valley turnout ties as a “poor man’s” jig-built turnout ala Fast Tracks works well. Not only is this approach a lot cheaper than the full-blown Fast Tracks jig method, it gives you turnouts that look better than the Fast Tracks ones – with full tie plate and spikehead detail. And of course, like the Fast Tracks method, the CVT turnouts are ultra reliable and as DCC friendly as it gets.
Here’s a photo of one of these finished turnouts, and I give all the details, step-by-step (with photos), for building these turnouts on my web site:
(Click image to enlarge)
If they only made them in N scale!
jfugate wrote:
I have another experience!
There were problems at the frog. The two rails at the frog toe are too close. The wheel (of tender trucks at steam engines especially) run on one rail - but the flange touches the other rail. With DCC the booster shuts down!
Therefore I would go with PROTO87 frogs or build your own. Another solution, you can make a cut in front of the frog through the rails. This way you get a longer dead spot or you wire this pieces together with the life frog.
Wolfgang
Yes, let me hasten to add that I build my frogs, I don’t use the CVT frogs.
If you gap the frog appropriately as I show in my how-to thread, you won’t have any problems.
Here’s a photo showing the gaps I cut with a motor tool cutoff disk:
After cutting the gaps, I superglue some gray styrene into the gaps and then trim it up with a fresh xacto knife blade. If you look closely, you can see the gaps all but disappear on the finished turnout:
If you follow the simple guidelines in my how-to thread, you will get a turnout that’s very DCC friendly.
When the seller has a 100% positive feedback and turnouts are the majority of what they sell you can read about the kind of quality they have produced in the past. Not to mention a good picture of the product gives you a good idea of what your going to get.
In my case the turnouts are excellent.
Bill
