This may be a question better suited for scenery section but here goes:
I have a structure kit that is molded in a fieldstone style pattern. Lots of windows, about 4" wide, 6-8" long and about 6" high. These are rough measurements. It is 2 stories tall with a narrow “3rd” floor in the middle along the length. Almost looks like a bell tower but it apparently will run the length of the structure.
I have no instructions for this kit and there are no part numbers stamped on the inner wall pcs so I know its not a Walthers kit. If anyone has a clue as to what the name or manufacturer of this kit is, pkease let me know.
Thabk yall very much!! The iron works is exactly what I have. I knew this was the place to ask. Sorry about the email address, old habit. Now alk I need to do is find a pdf of the instructions.
Here’s my version of the Novelty Iron Works, built with both long walls on the visible side of the structure (the back wall, along with interior partitions, and floors, plus the roof and its supports, were all done using .060" sheet styrene).
ETA: There is a thread about that kit from wdcrvr, but I get an error every time I try to post a link. HO Seeker has instructions from when the kit was made by Ertl, item 099-4687. There are also build threads on railroad-line forums.
I combined two kits here. Delany and another one I cannt remember. You can see the building you reffer to is in the front with multiples of that same building put together to make on bigger on in back. Unfinished abandoned building project.
