First impressions: TCS WOWSteam decoder w/questions
Greetings,
I installed my first TCS Wow101-Steam decoder in a Trix 2-8-2 Mike last night to replace the original Loksound V2.0 decoder that came with it and I am NOT disapponted with my choice. [Y][8D] The number of chuff and bell options is quite impressive but I - once again - especially enjoy the phenomenal motor-control of the TCS decoders.
I have a few comments and questions for those who have programmed the WowSteam decoders:
  • While it did take a little time to figure out, I used Audio Assist to successfully select the appropriate chuff (e.g medium) and eventually adjust the rate and master volume. Does anyone know if the Audio Assist volume itself be lowered, as well? Adjusting the master volume doesn’t seem to affect it at all and it’s quite loud.
  • The Sound List on the TCS site was helpful for identifying the correct values for CV 203 & 204 for the whistle I was looking for and I’m pleased with the results. It claimed that these could also be accessed using Audio Assist but I don’t see that as an option anywhere on the Audio Assist Programming map. Is this accessible only through the Sound Mapping Menu?
  • The chuff is constant when the 2-8-2 is moving in reverse but cuts out after 4 or 5 chuffs when moving forward. Would that have something to do with needing to initially perform the automatic chuff calibration, as described on the Audio Assist Programming map? I don’t have enough length of programming track to try that option.
I’m liking the performance and sound of the Wow101-Steam decoder enough that I may eventually end up replacing the “newer” Loksound V3.5 decoder in my other Trix Mike. While I do like Loksound decoders for diesels, their current sound file offerings for American steam is still fairly limited. That’s why I decided to give the WowSteam
Interesting, I have seeveral TCS-WOW decoders in locos and I like the sound and motor control. Never really got used to teh audio assist though. I use Decoder Pro and find it easier.
However I had the opposite experience you did and when I got a couple LokSound Select decoders I found sound to be more t my liking. They are harder for me to program without the LokProgrammer (which I will have soon [:)]).
I do like that the WOW decoders have onboard keep alive’s.
WOW sound decoders have a feature where the chuffs are louder when the engine starts up, or is going uphill, to represent the engine working harder. It might be that you have the chuff volume set where you can hear the loud starting chuffs but the later ‘normal running’ chuffs fade into the background?
You don’t have to do the audio programming on the programming track, you can just do it on the layout.
That thought had occurred to me, Stix. However, I thought the harder chuff would last longer than just a single (or <) rotation of the drivers.
And I’m WOAL (w/o a layout) at the moment so I’m stuck programming on the 27" long programming track. I will be getting a couple of sets of roller bearing stands so that will make programming and breaking in a bit easier in the future.
On the Tsunami decoders there is a CV controlling the duration of the louder ‘load’ chuffs when there is an increase in throttle setting. I wonder if the TCS has the same feature that needs to be adjusted to suit, Tom.
I don’t recall, but I wouldn’t be surprised if there also were CVs to separately control the volume of regular and ‘load’ chuffs.
Just a shot in the dark…some sound decoders are set up that when a steam engine starts up, the only thing you hear for the first couple of revolutions of the drivers is the loud hiss of the cylinder cocks. Then, when that sound is done, you can hear the chuffs. I don’t know for sure, but maybe if the CV for cylinder cocks is set to zero, it just doesn’t make any sound for the first few rotations until the chuffs kick in? If you’re limited to a short programming track, maybe the engine just isn’t going far enough for the regular chuffs to engage? On some of my BLI engines with that feature, the engines sometimes go 2-3 feet hissing at me before starting to chuff.
FYI: I emailed and received back a reply from Dan @ TCS. He said the following about the Audio Assist:
In order to prevent users from accidentally muting Audio Assist, we hard-code that volume, and it is not user configurable. Sorry if it blows out your eardrums!
I thought that might be the reason but figured I’d ask them anyhow. I might email TCS back and suggest to them that even a three-point option for the Audio Assist volume (e.g. 100%, 50%, and 25% - but no 0%) would be useful and still quite audible for the user. I wouldn’t think that would be too difficult to achieve code-wise?
In regards to the chuff issue, here is Dan’s response to that:
The chuff calibration can be performed as a “manual” or “automatic” version. The Automatic calibration will set the chuff intensity for both directions at the same time, based on your running conditions. The Manual calibration on the other hand only calibrates the sound in the direction of travel, as it is possible to have a motor with different characteristics in both directions. In order to account for this, you can manually calibrate each direction. If you already performed an automatic calibration and are happy with the performance in ONE direction, use the manual calibration to adjust the intensity in the other direction. You could also re-do the automatic calibration.
Note that a manual calibration ADDS or SUBTRACTS from the automatic calibration in each direction; therefore if you are unhappy with the calibration in one direction, simply re-do the manual calibration.
